Subject: Pietenpol-List: A65 eyebrow cowlings
RE: Pietenpol-List: A65 eyebrow cowlings
Steve,I put my brackets on the cylinder studs and then put the nuts back on. Besure to torque them per the engine overhaul manual. Also, be certain yourbrackets are steel, not aluminum. My first brackets were aluminum and Ifound that in about 50 hours the nuts got loose. Good way to blow a jug! Imentioned that to an old-time Cub guy and said, yeah you've got to usesteel. Aluminum will always "work" enough to let the nut get loose.Good luck!Jack PhillipsNX899JPSmith Mountain Lake, Virginia _____
Pietenpol-List: Re: A65 eyebrow cowlings
Thanks Steve. Very encouraging! Scott Sent from my iPhone> On Dec 16, 2013, at 10:08 AM, "Steven Dortch" wrote:> > Scott, It was my aerodynamacist buddy who explained how the scallops create a turbulence right next to the skin that is slicker than letting the air go across a smooth surface. This holds the boundary layer closer to the airfoil of the prop and thus provides better "lift" which translates into thrust in this case.> > it is somewhat counter intuitive but there it is. > > Blue Skies,> Steve D > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D________________________________________________________________________________Subject: Pietenpol-List: Re: A65 eyebrow cowlings
I believe Continental used Pal nuts to secure them. Only takes a couple of threads.AS&S sells them under MS27151.DaveRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 17 Dec 2013 03:41:01 -0800 (PST)
