Pietenpol-List: Feb 20 to 24, hangar gathering, doing "stuff", Cha
Original Posted By: "tools"
Up aileron is also in turbulent flow (aft of the separation point on the uppersurface of the wing) causing less of a control force. Greater deflection is therefora desired condition. Scott KnowltonSent from my iPhone> On Jan 3, 2014, at 9:39 AM, "Bill Church" wrote:> > > My assumption would be that it must be a typo. The geometry of the horn willresult in greater upward deflection than downward. And that is the way it shouldbe.> > Here's a clip from Wikipedia (so it MUST be true)> > Differential ailerons> > By careful design of the mechanical linkages, the up aileron can be made to deflectmore than the down aileron (e.g., US patent 1565097).[33] This helps reducethe likelihood of a wing tip stall when aileron deflections are made at highangles of attack. The idea is that the loss of lift associated with the upaileron carries no penalty while the increase in lift associated with the downaileron is minimized.> > And here's something from a website called Datwiki.net> http://tinyurl.com/m69jkjl> > > Differential Aileron Travel (airplane Control System) > > The difference between the upward and downward travel of an aileron. An aileronmoves a greater number of degrees upward than downward to counteract adverseyaw. The downward-moving aileron produces both induced and parasite drag, butthe upward-moving aileron produces only parasite drag. To prevent the combineddrag causing the nose of the airplane to start to move toward the down aileron,the up aileron travels a greater distance, producing enough additional parasitedrag to overcome the induced drag caused by the down aileron. See adverseyaw.> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 490#416490> > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Feb 20 to 24, hangar gathering, doing "stuff", Cha
I'm hosting an event I've done in the past primarily oriented towards helping folkswith projects with tools and skills they may not normally have available.I've had folks bring broken machine parts, and we either fix them or fabricatenew. Lots of demonstrations on stuff, some applies to Piets, some won't, althoughmore of it applies that might be obvious. We'll possibly be pouring metal,aluminum most likely. We could try making hinges... Dynamic balancing, wecould try my IRD Mechanalysis (a notch filter with a strobe setup that's generic,not specialized towards planes and propellers, but will work fine) balancer.We'll be playing with an old saw mill (have a poplar tree you need milledinto a Piet kit?). Some machine tools, lathes, mills, shaper. Plenty of woodworkingmachines. I've got a wing rib jig and can mill up some materials ifyou want to play with that. I do have a couple model a blocks laying around if someone wants to play with one.We could strip the block, evaluate the cylinders, even bore and hone... Could try setting up a line boring jig to machine out the block/caps for inserts.I've got the tools, have never done it... I'll have welders, we've tried gas welding aluminum with mixed results... HopefullyI'll have the TIG welder fixed if you need some stuff welded together, whatever.Lots of woodworking stuff, making and milling wood gear struts is prettyeasy. The place is a mess, but there's a fair amount of room so you can just crash whereever, how ever, the point is to keep it reasonably priced. No fees, registrations,rsvp's or anything. If you NEED something done, might want to discussit a bit so materials are placed, if we need to find some outside skill, wecan try, etc.I should have a career A&P IA available. He's got LOTS of experience restoringplanes, building motors, etc. Great resource. There's several nice grass stripswithin a few miles (my runway is still soft from the leveling work, so it'sprobably not usable) and we'll come get ya. Also available is Lafayette GAless than 10 miles. Ramp space and avgas. There are hotels near by, rides are easily available, whatever floats your boat.I'll probably definitely be doing some recover work on 2RN, all the damage is repaired,just to fix the fabric now. I'll be stripping latex, using Stewart glueto reattach, etc. The location is just south of Chickamauga GA (south of Chatt TN). I'll post gpscoordinates later.My hangar project is SLOW, but finally basically up and roofed... [img]http://us-mg4.mail.yahoo.com/ya/downloa ... x&inline=1[/img]So inclement weather shouldn't slow us down too badly. For northern folks, thismight be a decent break from the C O L D!! Some folks are coming from NJ, IL,IN. There might be 10 folks, there might be a hundred (expect less couch spacein that case...). Outside of tools and machining, there'll be a fair amountof eating (pass the hat, grill, get take out, whatever, not getting very formalhere) and drinking. Cheers,ToolsRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Feb 20 to 24, hangar gathering, doing "stuff", Cha
Original Posted By: tools
WOW Talk about the old EAA This would be a great place to go to wish i was younger and lived closer you dont want to adopt a 73 yr old kid do you ?Don-----Original Message-----
Pietenpol-List: Re: Feb 20 to 24, hangar gathering, doing "stuff", Cha
I sure wish you were my next door Buddy! How about you moving to the warm, sunnySacramento Valley of California?Guess I can't make it.Ray KrauseBuilding SkyScoutSent from my iPad> On Jan 3, 2014, at 7:55 AM, "tools" wrote:> > > I'm hosting an event I've done in the past primarily oriented towards helpingfolks with projects with tools and skills they may not normally have available.> > I've had folks bring broken machine parts, and we either fix them or fabricatenew. Lots of demonstrations on stuff, some applies to Piets, some won't, althoughmore of it applies that might be obvious. We'll possibly be pouring metal,aluminum most likely. We could try making hinges... Dynamic balancing,we could try my IRD Mechanalysis (a notch filter with a strobe setup that's generic,not specialized towards planes and propellers, but will work fine) balancer.We'll be playing with an old saw mill (have a poplar tree you need milledinto a Piet kit?). Some machine tools, lathes, mills, shaper. Plenty of woodworkingmachines. I've got a wing rib jig and can mill up some materials ifyou want to play with that. > > I do have a couple model a blocks laying around if someone wants to play withone. We could strip the block, evaluate the cylinders, even bore and hone...Could try setting up a line boring jig to machine out the block/caps for inserts.I've got the tools, have never done it... > > I'll have welders, we've tried gas welding aluminum with mixed results... HopefullyI'll have the TIG welder fixed if you need some stuff welded together,whatever. Lots of woodworking stuff, making and milling wood gear struts ispretty easy. > > The place is a mess, but there's a fair amount of room so you can just crashwhere ever, how ever, the point is to keep it reasonably priced. No fees, registrations,rsvp's or anything. If you NEED something done, might want to discussit a bit so materials are placed, if we need to find some outside skill,we can try, etc.> > I should have a career A&P IA available. He's got LOTS of experience restoringplanes, building motors, etc. Great resource. There's several nice grassstrips within a few miles (my runway is still soft from the leveling work, soit's probably not usable) and we'll come get ya. Also available is LafayetteGA less than 10 miles. Ramp space and avgas. > > There are hotels near by, rides are easily available, whatever floats your boat.> > I'll probably definitely be doing some recover work on 2RN, all the damage isrepaired, just to fix the fabric now. I'll be stripping latex, using Stewartglue to reattach, etc. > > The location is just south of Chickamauga GA (south of Chatt TN). I'll postgps coordinates later.> > My hangar project is SLOW, but finally basically up and roofed... > > [img]http://us-mg4.mail.yahoo.com/ya/downloa ... x&inline=1[/img]> > So inclement weather shouldn't slow us down too badly. For northern folks, thismight be a decent break from the C O L D!! Some folks are coming from NJ,IL, IN. There might be 10 folks, there might be a hundred (expect less couchspace in that case...). Outside of tools and machining, there'll be a fair amountof eating (pass the hat, grill, get take out, whatever, not getting veryformal here) and drinking. > > Cheers,> > Tools> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 494#416494> > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Feb 20 to 24, hangar gathering, doing "stuff", Cha
I adopt you, you adopt me... it's all the same! Seems there would be little adultsupervision either way!Where do you live? Might be able to arrange a ride. In the case of 73 young...the couch and air mattress would be out, we'll find you a bed and room! We'llcall it the booby prize for avoiding growing up longer than anyone else there...unless a octogenarian shows up... just sayin'.ToolsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Feb 20 to 24, hangar gathering, doing "stuff", Cha
Pietenpol-List: Re: Jake's progress
Thanks. It's not ALL that expensive. People tend to really kick in and help.We REALLY had fun at the first, the second was much smaller but still TONS offun. Seems the less "organized", the more productive and less stressful, meaning...fun. Otherwise, I didn't collect all this junk (most of it came off a scrap truck) forno reason. No way I'm gonna wear it all out. The main concern is space. In rural Georgia, it's reasonably priced. That hangar, everything you see in the picture of it has set me back about twogrand. Trusses and tin donated from a guy taking down a chicken house. Polesfrom the electric company for free, dimensional lumber from our sawmill and freelogs. About $500 in nails... and more nails... and a decent hammer for myson... hehe. I'm just lucky enough to have a place to put it.So, the philosopy is, if you were gonna pay someone a couple hundred to weld somestuff together, buy gas and come here instead. Lodging is as free as I canmake it, food is no more than anywhere else... you'll make some new friends,likely shoot some machine guns and see and play with some neat other equipment.Also a great venue to get parts moved around. I'll be making a trip from WI downto there before too long, more than willing to pick up Spruce in Madison andget it to GA, come there and get it when you can. Plenty of space to storeit indoors. Buy an engine somewhere and need it moved? Position a Corvair engineblock for the college so you can fly there later? All sorts of possibilities.Just would love to see some of the going ons associated with owwm.org happen hereas so much of it overlaps.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Jake's progress
thanks Douwe..... This whole "building an airplane" thing is a lot of work, yetit is very gratifying. I'm in the "five years done and a LONG way to go" phase.Appreciate the thoughts and feedback for motivation......--------Jake Schultz - curator,Newport Way Air Museum (OK, it's just my home)Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Feb 20 to 24, hangar gathering, doing "stuff", Cha
So Toolapalooza 2014 is set! [Laughing]I will see if I can get up there as I have several things that I could get done.I need the assistance as well as the equipment at the Danford Aeronautical WorksInc. I guess that means that I do not have the "tools" to do the job!I will give you a call.--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 4 Jan 2014 11:52:09 -0800 (PST)
Re: Pietenpol-List: Engine Cowling Help
Subject: Re: Pietenpol-List: Engine Cowling Help
RE: Pietenpol-List: Engine Cowling Help
Ken,As you said, Uncle Tony has good advice, including what I am about torepeat. I'm glad you took the time to access that information!My cowl came out nice, though I continue to modify it. One of my long termgoals will be to reduce the 5,347 stainless screws, by at least half! Withsome 'noodling' I am, little by little, gathering a plan to use pins (likeMike Cuy, Greg Cardinal and a few others.) instead of some of the screws. Iwill also be able to employ some piano hinges that will eliminate a couplehundred more screws.What I am finding is that removing and replacing the cowl is a dauntingtask, and I'm sure it discourages me from looking into the enginecompartment as often as I would like.Best wishes!Gary BootheNX308MB
Original Posted By: "pringljo"
Thanks! This has been a great learning experience, just asking for user's opinion.That's what so great about this forum.Thanks again,Ray KrauseSent from my iPad> On Feb 7, 2014, at 8:57 PM, glenschweizer(at)yahoo.com wrote:> > > Hi Ray> When welding anything,the strength of that weld is going to depend on many factors.The heat has to be suficient to melt all material to a temp > Witch allows them to flow into one another(100 percent penetration). Lack ofporosity is also critical. That is controlled with proper gas regulation andposition within the flame cone where the. Welding takes place. The low volumetorches might do very well for thinner material but maybe not so well on thickerstuff.> When you. Test your welds the material welded should break before the weld afterthAt. Cut or file the weld so that you can do a magnified inspection of yourwelds. Short of. X-ray that's been the most reliable method I've found toreally study them damned welds. Practice inspect practice practice> Sent from my iPhone> >> On Feb 7, 2014, at 8:26 PM, Ray Krause wrote:>> >> >> Oscar,>> >> Thanks for your opinion, which I respect highly. I did buy a kit of the Cobratorches because, as you said, they make it look easy. When he welded the 4130for me, I took it home and beat on it a little with the hammer, it did notcome apart. Tomorrow I will bisect it and see what the welds look like on theinside. The mild steel he welded had good penetration, but it was thin. I willtry some .090 and see how it works. Not sure my regulators will deliver 4PSI.It is all research! My thought was that the Cobra would be about the same costas getting all the setup for the smaller standard torches. But if I have toget new regulators, I will be spending even more money! Oh well, it's nothingmoney can't fix!>> >> Thanks,>> >> Ray Krause>> >> Sent from my iPad>> >>> On Feb 7, 2014, at 8:16 AM, "tools" wrote:>>> >>> >>> These things are really controversial... However, I like mine. >>> >>> I haven't really figured out how to use them correctly though. Like everything,the demos are a bit misleading, but only in they make it seem easier thanit is. However, they're CLEARLY doing it! And I really believe it'll do thingsa regular OA torch won't (though someone REALLY skilled could prove thatwrong I suppose).>>> >>> Like all OA sets, super versatile. I did weld some 4130 once early on andmade the MOST BEAUTIFUL looking welds ever... then tried some testing on them.Turned out there was NO PENETRATION at all. Really weird. >>> >>> So, while I also recommend them, I would also recommend really spending sometime with them until you really figure them out. Like ALL tools, they requireskill. There's nothing magic about them. I think most of the naysayers arefolks who are good at OTHER OA torches and figure if they can't make these work,they're smoke and mirrors. When it's probably more a case of they just don'tknow how to make THESE torches work.>>> >>> They really are super nice guys who will do their level best to get you going.I also recommend good regulators that'll do well at lower levels. Like mostchinese stuff, it's a matter of hit and miss, and longevity. Good regulatorsout of the gate will most likely save a lot of frustration.>>> >>> >>> >>> >>> Read this topic online here:>>> >>> http://forums.matronics.com/viewtopic.p ... 282#418282> > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Feb 20 to 24, hangar gathering, doing "stuff", Cha
Looks like a bright sunny day up there in Oregon! Nice day to give that ol' Birddome wings. Good work.Ray KrauseSent from my iPad> On Feb 8, 2014, at 8:01 PM, "taildrags" wrote:> > > Today was the day.... hung the wings. The last time the wings were on the airplanewas December 2012, when Steve Dortch, John Kuhfahl, Norris Warner, CraigWall, my brother David, and a cast of extras all helped me take the airplaneapart and load it into the big Ryder truck for the trip from TX to Oregon. Nowit's back together with all new wing and strut attach hardware and I just needto reconnect the control cables and replace the wing gap fairings and theairframe will be whole again.> > The list of to-do items is getting shorter. I should be able to put fuel init in a few more weekends. Got a fishing trip up Jake's way the weekend afternext for some winter steelhead at Grays Harbor, WA, but that's just a minor distraction;o)> > --------> Oscar Zuniga> Medford, OR> Air Camper NX41CC "Scout"> A75 power> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 392#418392> > > > > Attachments: > > http://forums.matronics.com//files/img_0611_859.jpg> > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Feb 20 to 24, hangar gathering, doing "stuff", Cha
Pietenpol-List: Re: Cobra Torches...
The answer to your second question... yes. At a pretty good pace.The first question, the formal addy is 335 Castlerock Ln, Chickamauga GA 30707.Informally, the closest exit off I 75 is Battlefield. The closest exit off I 59is Trenton. Off I 24 is tougher, Broad Street in Chattanooga TN...Basically, there's Chickamauga National Battlefield Park. Downtown Chickamaugais about 3 miles south of that, on Highway 27. Three more miles south of Chickamaugaon Highway 341 is where I live. The intersection of HW 341 and BondsRd. You can only go west. About 1/2 mile from there is a blue street sign forCastlerock Ln. you can only go north. At the end of that, about 1500 feet,is the place. Call from anywhere, we'll dispatch you in, 423 580 1383, or 423 596 7770.Look forward to meeting you!ToolsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Cobra Torches...
Been to Chickamauga GA once and that was back in high school when we played GordonLee in Football... Long drive and cold night.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Feb 20 to 24, hangar gathering, doing "stuff", Cha
Original Posted By: "gsnewsome"
Chickamauga to Savannah is a decent haul, especially for a HS football game!Got a couple other folks coming from Savannah... Think they're bringing oystersfor a roast.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Feb 20 to 24, hangar gathering, doing "stuff", Cha
That would be a haul. I lived in the surbs of Atlanta back then.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Feb 20 to 24, hangar gathering, doing "stuff", Cha
When are he savannah boys coming up? I love oysters. I will be bringing controlhorns up to weld and learn how to. Thanks, Airlion from LagrangeSent from my iPadOn Feb 9, 2014, at 10:26 AM, "tools" wrote:> > Chickamauga to Savannah is a decent haul, especially for a HS football game!> > Got a couple other folks coming from Savannah... Think they're bringing oystersfor a roast.> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 414#418414> > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Feb 20 to 24, hangar gathering, doing "stuff", Cha
I think all four days. Prob save the oyster roast for Sat night anyway, so noworries!Looking forward to making some control horns.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Got mine yesterday Feb.21 Thanks John for taking it over :) LarryRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Feb 20 to 24, hangar gathering, doing "stuff", Cha
Had a great time up at Mike's place today. Saw several acquaintances that I hadmet at previous events, and met several new friends as well. Mike was very generous,giving us free reign over his extensive tool collection. I was able toget a great start on my control horns. Also can't say enough about what a Wonderful hostess Mike's wife is. Amazing mealsfor a whole bunch of guys. Thanks so much.--------Joe PringleAtlanta, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Feb 20 to 24, hangar gathering, doing "stuff", Cha
RE: Pietenpol-List: safety wire
--> Pietenpol-List message posted by: "Gary Boothe" Fortunately, the manufacturer of NX308MB specified .020. Gary Boothe NX308MB -----Original Message-----
Original Posted By: larharris2 Harris
THANKS for coming! We actually had a pretty good showing of Pieters whom I thoughtALL integrated well with the old woodworking machines crowd.The weekend (still underway, just had a newcomer show a few minutes ago) was fantasticallyproductive. The Carrollton gang pledged to come early and stay nextyear to help (BADLY needed) mentor the Piet crowd with their projects.Everyone pitched in a lot to keep things moving. However, it was Kellie and Judywho, for no other than reason being saints, brunted the VAST majority of responsibilityfor folks being fed WELL and timely. My philosophy is let grownmen fend for themselves... probably flawed thinking anyway! Thanks to them!Hope to see more folks next year. There's some pics in the "events" section ofOWWM.ORG for folks who want to visit vicariously.Cheers,ToolsRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
A little more progress towards a return to flight. Got the oil screen out, cleaned,and the residue inspected (nothing seemed to be glittering in there). Thanksto Mike Cuy or whoever it was who suggested running the cleaning solventand residue through a coffee filter and then letting it dry to see what's inthere. Works great.Cleaned the carb inlet screen, drained the float bowl (and yes, I lifted the tailto try to get as much as I could out of there). Just looking for crud anywhereI can think of.Re-torqued the prop bolts and safetied them. I think everything is ready to go,firewall forward. Just need to reinstall my centersection flop and the newrear cockpit windscreen, check the brake fluid level in the masters, and I thinkit's ready to fuel up. That will have to wait till next weekend... too busyright now.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Feb 20 to 24, hangar gathering, doing "stuff", Cha
You are VERY welcome, it was my pleasure. I do hope to see you again next year.There should be a lot more Piet mentors there next year. Speaking of, youwould be a good mentor as you now have a feel for how things run and what it'slike. Thanks for coming!ToolsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: safety wire
By the way, and since the list is fairly quiet right now, I'll take a minute topost this. The words "safety wire" should be changed to something else. Everytime I have to safety something, I end up with more cuts than a governmentsequester and "safety wire" is quite unsafe when it comes to its tendency to drawblood. The two worst offenders are the .041 and the .020. The medium-sizedwire is fairly well behaved because you can bend it easily and tease it intoplace with your fingers, but the .041 is a beast to deal with unless you usepliers and the small stuff is like a tiny silver viper, just waiting to get youwith its little fang. And just try working it in a blind area without gettingbitten.The other thing about safety wire is that I waste a lot of it by re-doing the safetying.I can never remember the right way to safety pairs of things and Ihave to start over, or I cut the piece of wire just a little too short and haveto start over. I've also noticed that I get the dirty eye from A&Ps when Iuse any of the smaller sizes of wire. They want everything done in .041 unlessthe hole in the fastener simply will not pass that size of wire, and it's crazy.Why do we even have anything but .041 then? And why try fishing it throughall the little screws and jets and things on a Stromberg carb?My guess is that I could take my big old single-speed Craftsman 1/2" drill andchuck a fly cutter in it, then stake it down with a piece of .041 safety wireand try to bore a hole in some kind of gnarly material with the fly cutter off-axis,and that thing could bite and claw and try to torque itself like a forkin spaghetti and a single strand of .041 could hold it. Why in heaven's namewe need to put that heavy safety wire on little fasteners and turnbuckles I willnever know.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Fortunately, the manufacturer of NX308MB specified .020.Gary BootheNX308MB-----Original Message-----
I didn't take a single one! However, there are some posted in the "events" section of www.owwm.org, in a thread about "Toolstock". More will show up. I'll also get sent some videos a buddy took and will post themhere when they show up.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 24 Feb 2014 05:32:30 -0800 (PST)
Pietenpol-List: Re: safety wire
What size are you using to safety wire turnbuckles?John--------John FrancisRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: safety wire
.020Gary BootheNX308MB-----Original Message-----
Oscar,Are you using a safety wire tool to twist the wires, or are you trying to doit by hand? A safety wire tool makes it pretty easy (except forturnbuckles, which are just a pain in the butt).You can get a decent (Chinese) safety wire tool for $20 or less. A good onewill run about $60.Just remember to always put the wire on in such a way that the wire isforced to get tighter for the nut or bolt to loosen.Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
