Pietenpol-List: Airspeed indicator
Pietenpol-List: Re: Airspeed indicator
etenpol-list(at)matronics.com>Subject: Re: Pietenpol-List: Airspeed indicatorI get the same eye roll here everyday especially when cxed checks come in from aircraft spruce and wicks.. the ac 43 13 1b is on line at faa.gov for free.. I hate e books but free is free and no eye roll:-)jimOn Monday, March 17, 2014 9:37 PM, Steven Dortch > wrote:Jim, I cannot find my copy. Uncle Tony talks all around it. (I now know how to calibrate airspeed by lengthening or moving the pitot.) But I cannot find my AC 43-13-1B. My wife just rolled her eyes when I asked her.I am reasonably sure the torque is between finger tight and two 180 pound men on the end of a 3 foot cheater bar.Blue Skies.Steve DOn Mon, Mar 17, 2014 at 9:11 PM, jim hyde > wrote:consider checking your 43-13-1B for torque valuesjimOn Monday, March 17, 2014 8:55 PM, Steven Dortch > wrote:How tight should the fitting that screws into the airspeed indicator be?--Blue Skies,Steve D" target="_blank">http://www.matronics.com/Navigator?Piet ... tion--Blue Skies,Steve D________________________________This e-mail message (including any attachments) is for the sole use ofthe intended recipient(s) and may contain confidential and privilegedinformation. If the reader of this message is not the intendedrecipient, you are hereby notified that any dissemination, distributionor copying of this message (including any attachments) is strictlyprohibited.If you have received this message in error, please contactthe sender by reply e-mail message and destroy all copies of theoriginal message (including attachments).________________________________________________________________________________Subject: Pietenpol-List: Re: Airspeed indicator
Subject: Pietenpol-List: Airspeed indicator
Original Posted By: jim hyde
Pietenpol-List: Re: Magneto switch wiring
Original Posted By: "Boatright, Jeffrey"
Mario;Attached are some photos that might help. At the magneto, I grounded the braidedwire shield and then I used a rubber boot to cover the P-lead lug. At theignition switch, I connected the P-lead wires from the magnetos to the Right andLeft magneto connections and ran a ground wire from my common ground referencelug (a stud on the metallic firewall) to the Ground connection on my ignitionswitch.I have a flexible braided grounding strap from the engine block to the ground referencelug on the firewall, too.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/igns ... __________
Original Posted By: jim hyde >
Agree about free is free and not liking reading shop books as ebooks, but at least the free version at faa.gov has high-quality illustrations. My much abused copy in the hangar can no longer make that claim=85BTW, I was able to find the table for generic torque values based on bolt/thread size, but that's for steel. Would those hold true for the materials used for airspeed indicator hardware? I am not sure. Being lazy physically and mentally, I just hand-tightened mine (7 years and many hours ago), but then, my nickname at the field is "Captain Torque". I break things worse than Baby Hughey.--Jeffrey H. Boatright, PhD, FARVOAssociate Professor of OphthalmologyEmory University School of Medicine
Pietenpol-List: Re: Marvin Haught---try Harry Fenton's Web site on Small
Original Posted By: "biplan53"
So let's think about the application. Air stagnation (ram air) pressure at 160MPH is about a half a psi. Screw the fitting in enough to hold back that amountof pressure ;o)--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Marvin Haught---try Harry Fenton's Web site on SmallContine
ON April 23 at 7:00pm the EAA is having a websimenar. One of them is Mr.Fentondiscussing small Continental Engines. If there is an opening left you might beable to sign up. I bet someone at EAA could help you get signed up.--------Building steel fuselage aircamper.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Magneto switch wiring
Very clear Oscar, thank you very much.--------Mario GiacummoPhotos here: http://goo.gl/wh7M4Little Blog : http://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 18 Mar 2014 07:19:01 -0500Subject: Re: Pietenpol-List: Airspeed indicator
Builders,We are now just 10 days away from Corvair College #29 in Leesburg FL., Followedthe SnF, (where I will be there just to give some forums, hang out a the Zenithbooth and go see Dick and the gang at the woodshop). From this point forward,we are in the busiest 120 days of the year leading to Brodhead and Oshkosh.It is a long stream of 12 hour days in the hangar. Productive work, especiallyon planes, is not punishment to me, I like it. But to do it day after day effectivelyrequires getting into a groove, and to do this I spend a lot less timeon the net, just covering our websites and email.In the past 6 years I spent a total of 10 days at Brodhead, and less than 10 hoursreading this list, yet I know a bit about most of the people who write in,even the ones not using a Corvair. I have two people specifically to than forthis connection, Doc and Dee Mosher. In the six years the covered the newsletter,I devoured each issue, reading every bit of each one many times. The wallsof our home are lined in bookshelves, but the back issues of the BPAN live inan honored and accessible place on coffee table. Contrast this with the factlet my EAA membership lapse for 2 years without noticing, because I have notbothered to even look at an issue of Sport Aviation in years.Doc and Dee are the glue that gave many of us a strong connection to Pietenpolsand each other. Words are failing me to explain how strongly I feel about that.In the 1990s, the newsletter didn't make me feel that way. I loved the planeI was building but the newsletter of that era had nothing technical in it, wasjudgmental of non-Ford builders, and portrayed Brodhead as a place to buy aBrat a look at old cars. My world view was shifted by chance when a Piet Guynamed Randy Bruce stopped by my house in Daytona beach, to drop of a stack of100 photos of Brodhead 1991. This was a clean cut guy in his 60's who only flewContinentals, going out of his way to make a 28 year old guy with long hairand a Corvair project feel included. Take that single act of generous spirit away,and my world would have been diminished to accepting a negative man's viewof who was welcome to appreciate Bernard's legacy. Every time I have read Docand Dee's work, I have thought about how their inclusive, pro-people stancehas welcomed in countless people just as Randy Bruce's visit to my home did.It is hard to find words to express the depth of my gratitude for this.--------------------------------------------It may seem as if I have written a lot here in the last weeks, but I ask your indulgenceand understanding it is all based on enthusiasm for people, buildingand ideas. I have spent many hours each night in the last weeks reading the listarchives to learn more about people's planes and perspectives. Time well spent.Flying season is back in full swing down here, and the start of each spring makesme feel this way. If you are up North and haven't been to the airport in months,go there on the next clear day and just stand by the side of the runwayalone for 30 minutes and think of all the places you can go and visit this season,all connected by nothing more than thin air. Open your hand and swing yourarm, it offers little resistance and no support, yet in your shop you are creatinga magic device that will allow you to move at will through a sky full ofnothing but thin air.-------------------------------------------------I hope to see as many of you as possible at Brodhead and Oshkosh. All you guysplanning the "85th" into Oshkosh, please keep me in the loop. You can count onmy full assistance no matter what you guys cook up. You can email me direct atWilliamTCA@aol,com or just call the shop line 904-529-0006. If you guys haveCorvair or W&B questions, send them, we will cover it. Call anytime, I work alot of late nights past midnight. It rings only in the shop, you will not bebothering us if call at 11pm. -ww.----------------------------------------------------To keep up with our news and idea blog:http://flycorvair.net/Our main page of information:http://www.flycorvair.com/Our Pietenpol specific webpage:http://flycorvair.net/2013/11/28/corvai ... page/.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Airspeed indicator
AC 43.13-1B: WF2--------Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Airspeed indicator
Pietenpol-List: See you at Brodhead
> To: "pietenpol-list(at)matronics.com" > Subject: Re: Pietenpol-List: Airspeed indicator>> I get the same eye roll here everyday especially when cxed checks come> in from aircraft spruce and wicks.. the ac 43 13 1b is on line at faa.govforfree.. I hate e books but free is free and no eye roll:-)>> jim>>> On Monday, March 17, 2014 9:37 PM, Steven Dortch steven.d.dortch(at)gmail.com> wrote:> Jim, I cannot find my copy. Uncle Tony talks all around it. (I now know> how to calibrate airspeed by lengthening or moving the pitot.) But I cannot> find my AC 43-13-1B. My wife just rolled her eyes when I asked her.>> I am reasonably sure the torque is between finger tight and two 180 pound> men on the end of a 3 foot cheater bar.>> Blue Skies.> Steve D>>> On Mon, Mar 17, 2014 at 9:11 PM, jim hyde wrote:>> consider checking your 43-13-1B for torque values>> jim>>> On Monday, March 17, 2014 8:55 PM, Steven Dortch steven.d.dortch(at)gmail.com> wrote:> How tight should the fitting that screws into the airspeed indicator be?>> --> Blue Skies,> Steve D>>> *>> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution >> *>>> --> Blue Skies,> Steve D>>> *>> ">http://www.matronics.com/Navigator?Pietenpol-List > ics.com > .matronics.com/contribution >> *>>> ------------------------------>> This e-mail message (including any attachments) is for the sole use of> the intended recipient(s) and may contain confidential and privileged> information. If the reader of this message is not the intended> recipient, you are hereby notified that any dissemination, distribution> or copying of this message (including any attachments) is strictly> prohibited.>> If you have received this message in error, please contact> the sender by reply e-mail message and destroy all copies of the> original message (including attachments).>> *>>> *>>-- Blue Skies,Steve D________________________________________________________________________________Subject: Pietenpol-List: See you at Brodhead
