Cliff,In response to your question, "Doesn't everything below it act like a pendulum? The short answer is NO, that said, some explanation is required...In a properly designed and built airplane - the designer sets the CG so that theplane is slightly nose heavy, which, in flight, requires an equal and oppositetail down force. Now on the surface this may appear to be a pendulum, butin fact, its quite different. The purpose of nose heavy, coupled with tail down force is what gives us pitchstability. In other words, the plane will tend to stabilize itself in flightwhen you take your hands off the stick - and return to whatever pitch it's trimmedfor, assuming, of course, that you've trimmed the plane for a given pitchattitude, i.e., climb, cruise, descent.What is somewhat bothersome is that many on the list have indicated that the elevatoron a Piet "droops" during cruise flight, when in fact, the elevator shouldbe slightly up, in order to provide the tail down force. Perhaps the horizontal stabilizer on the Piet is - HERESY COMING - improperly designed,but satisfactory. If the angle of incidence of the stab were changedsomewhat, this condition might be corrected...Personally, I'd like for Jack Phillips and a few of the others to comment on thedrooping issue, as I'd like to make sure the plane I build is flying "correctly."I KNOW, I KNOW, I KNOW, BUILD IT PER THE PLANS, AND IT WILL FLY.... that stilldoesn't satisfy the Mechanical Engineer I am.... just sayin.--------Tom KreinerRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Speaking of outdated stuff? Center section fuel tanksvs. n
