Pietenpol-List: Elevator stops
Original Posted By: "Chris"
Happily I am at the covering/priming stage on the Air Camper. Before coveringthe fuselage I am dealing with a few details and one is assuring I have controlstops. A search of the archives gave me plenty of ideas on the ailerons (thighsseem to work well) and ruder. Not so much on the elevator. So, I wouldlike to hear from anyone regarding their solution. I am thinking I will weldto the torque tube some configuration fore and at of the pilot's stick. I justdon't know what, exactly, and perhaps there is something simpler. I am attaching a pic of my fuse. assy. as it appeared when I presented a programmy EAA chapter a couple weeks ago. Gettin' there!!--------Robert CaldwellHolly Lake Ranch, TXHangar at Mineola-Wisener (3F9)Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/apri ... __________
RE: Pietenpol-List: Elevator stops
Simplest control stop is a metal bar with a slit in it. One end attaches tothe stick and one end attaches to the pulley under the seat. http://westcoastpiet.com/images/Mike%20 ... w.jpgChris T.Sacramento, CaWestcoastpiet.com-----Original Message-----
That's good news, Robert! I hope to someday sit in that nice, comfy seat youbuilt!You should get some good advice on stops, but, to be honest, I have no stopson any controls! The stick hits my knees before bottoming out...the rudderpedals only have so much travel...and the elevator the same. Gary BootheNX308MB-----Original Message-----
Re: Pietenpol-List: Elevator stops
Subject: Re: Pietenpol-List: Elevator stops
Pietenpol-List: Re: Elevator stops
Thanks Mike, Chris, Jack... (and Frank)... How elegantly simple. I knew, as always,I could depend on the list to help me out. I will proceed to adapt thisidea and see no reason it will not be the answer. Gary, I too look forward... you can sit in mine if I can sit in yours.--------Robert CaldwellHolly Lake Ranch, TXHangar at Mineola-Wisener (3F9)Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Elevator stops
Re: Pietenpol-List: Re: Elevator stops
Original Posted By: Jack
Mike and Jack,Have you ever had to replace that bolt that slides in the slot. It looks likea neat idea, but I would think the shank of the bolt would wear without some greaseon it. Just curious.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: Elevator stops
Still building Sent from my iPhoneOn May 8, 2014, at 1:45 PM, "AircamperN11MS" wrote:> > Mike and Jack,> > Have you ever had to replace that bolt that slides in the slot. It looks likea neat idea, but I would think the shank of the bolt would wear without somegrease on it. Just curious.> > --------> Scott Liefeld> Flying N11MS since March 1972> Steel Tube> C-85-12> Wire Wheels> Brodhead in 1996> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 020#423020> > > > > > > > > > ________________________________________________________________________________
Scott-I spray all my controls, including that bolt that rides in the slot on the elevator stop strap with a thin film of silicone spray every springand haven't noticed any wear to date.Mike C.OhioHave you ever had to replace that bolt that slides in the slot. It looks like a neat idea, but I would think the shank of the bolt would wear without some grease on it. Just curious.--------Scott Liefeld________________________________________________________________________________Subject: Pietenpol-List: Re: Elevator stops
Thanks Mike, Since I am an EAA Tech counselor I like to see what works and has been proven.Your's is a great example and I can share with other builders what methods havebeen used successfully and safely. Thanks for the reply,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Elevator stops
The elevator stop on my airplane is the same as Mikee's. And by the way, Mikee-don't think I didn't notice what was in the background in that photo of yourelevator stop. USDA approved smoke oil dispenser ;o)--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Elevator stops
...and Mikee, just to worry you a little bit more, lately we're having a big politicalbrouhaha about outlawing genetically modified crops here in Oregon. Haveyou ever gone back to look at farm areas where you've flown over with yournoxious "barnstormer smoke" pouring out the stacks? I'll bet that Canopus oilis genetically modifying the alfalfa and beans and creating more death-defying"aviators" like yourself. Scary thought.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: Elevator stops
Hey Oscar Just a thought. Regarding changes in design that the curmudgeons comment about:are they a result of evolution or are there GMO pietenpols flying around outthere?Sent from my iPhone> On May 8, 2014, at 2:51 PM, "taildrags" wrote:> > > ...and Mikee, just to worry you a little bit more, lately we're having a bigpolitical brouhaha about outlawing genetically modified crops here in Oregon.Have you ever gone back to look at farm areas where you've flown over with yournoxious "barnstormer smoke" pouring out the stacks? I'll bet that Canopusoil is genetically modifying the alfalfa and beans and creating more death-defying"aviators" like yourself. Scary thought.> > --------> Oscar Zuniga> Medford, OR> Air Camper NX41CC "Scout"> A75 power> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 029#423029> > > > > > > > > > ________________________________________________________________________________
Re: Pietenpol-List: elevator stops and smoke oil !!!
Original Posted By: Gardiner Mason
Good eye Oscar! Yes sir, that is my liquid collision avoidance system in and around airports and for doing fun buzz jobshere and there.I'm not sure if the smoke oil (glorified mineral oil) I've sprayed has caused any root rot or bottom defoliation or has been modifiedfrom the smoke oil bean they extract if out of but it would probably would work great as a laxative if you're constipated. No extra charge.I'm here every Thursday folks and don't forget to try the veal.Mike C.Ohio[cid:image001.jpg(at)01CF6AE9.953F46B0]________________________________________________________________________________Subject: Re: Pietenpol-List: elevator stops and smoke oil !!!
What makes your smoke oil so dark. All the smokers I have seen have been putting out white smoke. What say yee Michael? GardinerTSent from my iPad> On May 8, 2014, at 6:16 PM, "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" wrote:> > Good eye Oscar! Yes sir, that is my liquid collision avoidance system in and around airports and for doing fun buzz jobs> here and there. > > I=99m not sure if the smoke oil (glorified mineral oil) I=99ve sprayed has caused any root rot or bottom defoliation or has been modified> from the smoke oil bean they extract if out of but it would probably would work great as a laxative if you=99re constipated. No extra charge.> I=99m here every Thursday folks and don=99t forget to try the veal. > > Mike C.> Ohio> > ________________________________________________________________________________Date: Thu, 8 May 2014 15:52:09 -0700 (PDT)
