Original Posted By: "DJ Vegh"
Group, It's time for me to put together my instrument panel, I would like toknow what type and brand I should use, also what instruments do I need? thisis for my Model A powered Pietenpol.ThanksKen HannanTemecula, CA________________________________________________________________________________
Pietenpol-List: Instrument Panel
Original Posted By: "K5YAC"
Greg,The best thing to do is to ask around for an old Temp gauge with a capillary tubeand use it. Someone will probably just give you one. Automotive or aircraftwill work. The capillary tube is the gasket that seals it and keep it fromleaking. That is your best bet. It doesn't need to work. In fact you can cutthe gauge off and just use the tube with the nut. Good luck.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Instrument Panel
Been getting back into making some progress lately... thought I'd share how myinstrument panels were fabricated. If anyone is interested in similar work, shootme a note. https://www.youtube.com/watch?v=fBitsTX ... ------Mark ChouinardWings, Center Section and Empannage and Fuse framed up - Working on Landing GearRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Instrument Panel
Impressive, Mark! That's a little more exact than my method of turning outthe lights, throwing a dart, and carving out the holes with my pocketknife...Gary BootheNX308MB-----Original Message-----
Re: Pietenpol-List: Instrument Panel
Subject: Re: Pietenpol-List: Instrument Panel
Pietenpol-List: Re: Instrument Panel
...and isn't a standard spark plug copper gasket the same as an AN900-10?--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Instrument Panel
