Original Posted By: "john francis"
Douwe, how about trying a solar panel while atbrodhead. GardinerSent from my iPad> On May 23, 2014, at 5:37 PM, Douwe Blumberg wrote:> > > HI all,> > Last fall I noticed my battery was cooked. since it was on the engine mount,we guessed it was too close to the engine. moved it to the firewall, no joy.I then was told that I'm an idiot, because my voltmeter all along was tellingme the generator was putting out 18 volts, which I thought was okay. so, wechecked the generator and found the field was grounded so I just replaced it.still overcharging...> > I have a zertronics "generator controller" which is a newfangled electronic gizmo,which the tech says "cannot overcharge" as it will simply shut down overa certain voltage, UNLESS the gen field is grounded. which it was.> > so, the only thing left in the system we haven't addressed is that darn generatorcontroller. zeftronics is shut until tuesday, at which time I'll talk tothe tech again.> > I wonder if it could act like that if I have it wired up wrong somehow. My mechanicfriend wants me to find an old-school points type and dump the new onein the river... anyone have one sitting around??> > it's not cutting into flying time as I just keep the batt charged for starting,but it would be nice to be all good for Brodhead.> > I've put about 15 hrs on her this spring. the weather has been great!!!> > Douwe> > > > ________________________________________________________________________________Subject: Pietenpol-List: Laminating Plywood
Pietenpol-List: Re: Laminating Plywood
Original Posted By: "tools"
It appears I will be coming up a little short on 1/8 inch plywood but have plentyof 1/16 left. Is it acceptable to glue pieces together to get the desiredthickness?John--------John FrancisRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Laminating Plywood
Ya. How big are the pieces you are thinking about?Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Laminating Plywood
Sent from my iPhone________________________________________________________________________________Subject: Pietenpol-List: Re: Laminating Plywood
For nonstructural parts as you described, that would be fine. Just use as muchweight as needed on the total part to get a good void free bond line. A laminatingresin like West System would work fine.--------Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Laminating Plywood
Definitely will work. I even think it would be fine for some of the smaller gussets(the 3x4 inchers and such) as you can put enough force on them to get areally good glue joint. Really large areas are pretty tough. Lots of cauls and clamps.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sun, 25 May 2014 01:11:47 +0000 (UTC)
