Re: Pietenpol-List: Re: a common place to undersell yourself---diagonal
https://www.facebook.com/www.CONTACTMagazineBuilder/ pilot, owner-operator of NX929DH, Captain Dan Helsper of Loensloe Air Service has made the cover of CONTACT! Magazinewith his beautiful Model A Ford powered Pietenpol Aircamper. Way to go Dan![cid:image001.png(at)01CF9C18.7BB26230]________________________________________________________________________________Date: Thu, 10 Jul 2014 08:54:59 -0500Subject: Re: Pietenpol-List: Re: a common place to undersell yourself---diagonalstruts
Pietenpol-List: Re: a common place to undersell yourself---diagonal struts
Yes, that's right. However, the photo on the Facebook page is not what the coveractually looks like. Pat has added a commemorative medallion for the 85thanniversary. Be at Brodhead or Oshkosh and get your copy of the magazine...--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: a common place to undersell yourself---diagonal struts
Very nice work. I built mine with open springs via the Cub/GN-1 plans (but I thinkthe Pietenpol design you used is better). Like a moron I paid no attentionto those that said that the springs should be pre-compressed. So now in orderfor my axles to be horizontal at gross weight I will need to shorten each spring-strutby around an inch and a half. Gear works fine though, am thinking aboutreplacing mine someday with the Pietenpol design using the same springs andan inch and a half shorter.rh--------Rick HollandNX6819ZRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/gear ... ___Subject: Pietenpol-List: Re: a common place to undersell yourself---diagonal struts
RE: Pietenpol-List: Re: a common place to undersell yourself---diagonal
Don=99t I wish I had that two weeks ago, making some changes to the forward rudder pedals!!!Gary BootheNX308MB
Pietenpol-List: Re: Landing gear about finished
I did add in the 2 degrees of camber like the plans call for... I don't know ifthat will be enough, time will tell.. I think I will wait to finish weld thestruts until after I mount the engine. I have a lot of room to extend or shortenthem where they enter the 1 inch tube that comes out of the spring housing. I also considered building the center a frame like the cub gear so the offsetof the struts wouldn't be necessary, but decided against it. I wound up with a pretty good offset at the wheel end of the struts but Ithink it will be Ok...Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/land ... ______Date: Fri, 11 Jul 2014 01:09:02 +0000 (UTC)
Pietenpol-List: Re: Brodhead 2014
Original Posted By: "fastj22"
Looks like there are three sizes, small, large and heavy duty. Is the small sufficientlystrong enough to use for lift struts?Also on the topic of lift struts, why are steel airfoil ones from ACS so expensivecompared to these?Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Brodhead 2014
My son and I are planning on flying our Sonex from Denver to Reedsburg, WI on July26th, then getting up early and head down to Brodhead either Saturday lateafternoon or Sunday morning for a few hours. Then up to OSH at noon for thebig show.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
