Pietenpol-List: be careful of scammers
Original Posted By: "aviken"
Hey Scott.. Great looking Gear.. I was so happy when I finally finished mine.. Nothing like the feeling of accomplishment to see your bird sitting on heron 3 legs... Then sadly you will have to remove all that hard work to sand andvarnish and cover and paint ect ect.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: be careful of scammers
Pietenpol-List: Re: be careful of scammers
Original Posted By: "bdewenter"
Thank you William...will email soon!Scotty--------Tamworth, AustraliaBuilding a Corvair Powered Pietenpol Air Camperwww.scottyspietenpol.comFuslage now on its undercarriage! About to start wing spars...Corvair engine atRoy's Garage waiting to be modified.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: be careful of scammers
William,Great info! Just what I needed to get started on the LG as well as giving me insightinto getting the W & B right the first time.If I was interested in having you build a motor mount for me what is the best methodto get you the exact dimensions of my motor mount brackets on the fuselage?Thanks for taking your time to assist me with this W & B issue.Grant ZiebellSavannah, TNRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: be careful of scammers
Original Posted By: "Braniff1966"
Grant,The only number we need to know is the width of your plane from the inside faceof the outer mount bracket to the same spot on the other side. It will be veryclose to 24" or 24.25". .Right now, sitting on the back porch is a 24.25" model, done powder coated thelight gray we use on most stuff. (Our powder coater is across the street fromNAS Jacksonville, so you can always have anything done in "US Navy haze gray"in short order, they are always applying it.) If you need one done in a differentwidth, we can get to it in a few weeks, probably before Barnwell..Scotty....I just learned yesterday about how to ship stuff down under at reasonablerates. I was speaking with Dan Weseman, and they have sold 6 Panther kitsinto NZ and Australia since Oshkosh and he has found a freight company in Californiathat sells space in Containers that leave nearly every day and make thetrip in 12 days. I good resource for big items like mounts and core engines.-ww.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: be careful of scammers
ididnt post the note in order to get an assestment of the principals that i spokeabout... i will admit that the dunning kruger effect applies to most messagesposted here including that one..jimRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: be careful of scammers
