Re: Pietenpol-List: straight axel landing gear fittings---sketches
Original Posted By: charlescampbell1924(at)gmail.com
When I built my landing gear for NX40072 I had the supplement plan from Don P with the full scale drawings of each piece. I just made card patterns of each piece laid them on the specified thickness of sheet metal and cut them out using whatever tools I had=2C shaped and drilled and they were good to go. Date: Fri=2C 3 Oct 2014 09:18:23 -0400Subject: Re: Pietenpol-List: straight axel landing gear fittings---sketches attached
Pietenpol-List: Re: straight axel landing gear fittings---sketches attached
ChuckDo you have a copy of the plans because all this information, and more, is on there.If not they are in the flying and glider magazine sold by EAA. Not sureif you can order full size plans or not. Mike's modification is the same thickness steel. All that changes is the innerfitting (tabs get bent down) and the additional piece on the inside/top. Justmake this piece so it fits your plane.--------ChrisSacramento, CAWestCoastPiet.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
