Original Posted By: Timothy Willis
gboothe wrote:> You taxi fast! Sometimes I do, too, when I have to pee...> > I tried a fin-mounted camera, but get way too much vibration. Yours isnt badat all.> > Gary Boothe> NX308MB> > > --I'll send along photos of the mount. If you think my trim mechanism is cheapo,you'll love this camera mount.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 17 Nov 2014 08:41:47 -0600Subject: Pietenpol-List: Starter solenoid
Pietenpol-List: Re: Starter solenoid
Hi Jeff,Nice video. I don't have the patience for that kind of thing. Anyway, if all you are using the Battery for is starting then you don't need thesecond solenoid. That is what the cable type starter is doing for you. Ifyou are running power to your radio through the firewall mounted solenoid thenit might be advantageous to keep it. At least you can shut the power off whenthe plane is parked. Good question. Cu-do's for recognizing it as extra weight or even more stuff togo wrong. Happy Landings,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Starter solenoid
