Please change my address from isablcorky@aol .com to isablcorky@gmail .comSent from my iPad________________________________________________________________________________Subject: Pietenpol-List: Aerial progress
Pietenpol-List: Re: Aerial progress
Just stumbled upon this searching "Pietenpol" in YouTube at lunch time.Mike C.http://chronicle.augusta.com/stories/20 ... ___Subject: Pietenpol-List: Re: Aerial progress
Re: Pietenpol-List: Re: Aerial progress
Dh60,and Dh82 tigermoth have mag switch located on the port side exterior . They've always been that way for safety. Of the guy flipping the prop. Glen Aerial in progressSent from my iPhone> On Feb 10, 2015, at 1:51 PM, Steven Dortch wrote:> > Oscar mentions the thought of putting the Primer up front where you hand prop.> > My FlyBaby buddy has his mag switches up front on the outside so that he can turn them on and off when he is hand propping. He can also reach them from the pilot seat. That way he is not going around the wind and back and forth.> > What do y'all think?> > -- > Blue Skies,> Steve D> > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> ________________________________________________________________________________Subject: Re: Pietenpol-List: Re: Aerial progress
Pietenpol-List: Piet on eBay
Original Posted By: Jack
Thank you for the invitation to Frazer Lake. I've offered to "fly" ground supportfor Oscar. I hope he'll fly Scout from Medford. I definitely plan to bethere. Blauer Himmel GlenSent from my iPhone> On Feb 10, 2015, at 1:44 PM, "AircamperN11MS" wrote:> > > Glen,> > It looks good. It's amazing how quickly the structures take shape. I hope tosee you come down to the Piet gathering at Frazier Lake in June. Bring someparts you have made and show them off.> > Keep it up my friend, Cheers,> > --------> Scott Liefeld> Flying N11MS since March 1972> Steel Tube> C-85-12> Wire Wheels> Brodhead in 1996> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 221#438221> > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Piet on eBay
Re: Pietenpol-List: Piet on eBay
http://www.ebay.com/itm/PIETENPOL-AIRCA ... S:1120Sent from my iPadJack Textor________________________________________________________________________________Date: Wed, 11 Feb 2015 10:51:07 -0600Subject: Re: Pietenpol-List: Piet on eBay
Ya mean moss growth on the north side of cabanes has been replaced by what? And I know I'm going fast enough when I can't hear her yellin from the front pit.Sent from my iPhone> On Feb 11, 2015, at 8:51 AM, Steven Dortch wrote:> > looks positivly high tech.> > Altimeter, compass, airspeed and VSI.> two radios, clock, intercom, engine instrumentation, Parking brake. interesting location for ELT> Is that a G-meter?> I see carb heat and (I think) mixture, what is the other lever for in front of the throttle?> mine is a lot simpler.> My commo gear is a megaphone.> Airspeed is done by throwing a piece of wood on a rope overboard and counting the knots on the rope as it feeds out.> My compass is a magnetized needle setting on a leaf in a bowl of water which is much better than using the moss growth on the north side of the cabanes.> > -- > Blue Skies,> Steve D> > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> ________________________________________________________________________________
Re: Pietenpol-List: Pietenpol biplane project-- Glen
R2xlbuKAlGxvb2tzIGxpa2UgeW914oCZcmUgbWFraW5nIGdyZWF0IHByb2dyZXNzIG9uIHlvdXIgUGlldG5lcG9sIGJpcGxhbmUhDQoNCkRvIHlvdSBoYXZlIGEgY29sb3Igc2NoZW1lIGFuZCBlbmdpbmUgcGlja2VkIG91dCBieSBjaGFuY2UgeWV0Pw0KDQpNaWtlIEMuDQpPaGlvDQoNCg=________________________________________________________________________________Subject: Re: Pietenpol-List: Pietenpol biplane project-- Glen
Pietenpol-List: Re: Piet on eBay
Hello,MikeI plan to use a William Wynne Corvair conversion of 110 HP. This engine will be built with a fifth bearing and billet crank. I've given lots of thought to a color scheme and have decided to go with an adaptation of the British Cammoflage used on the dH82 Tigermoth. I'm thoroughly enjoying the build process. I'm doing most of the build at my brother's shop about40 minutes from home. Ribs are being built at home and I'm currently kitting all the parts for the top wing. They're standard pietenpol. The lower wing ribs are the same profile but smaller. With 28ribs on top and 24 on the bottom, I'll be pretty busy. While I'm on the subject of ribs, I made a prototype from the rib jig to double check measurements of a finished product. I used CA glue for this and decided to make a test piece as I do for every batch of T-88. In testing to destruction, I got the same results. Any thoughts on using CA glue instead of T-88 for the ribs?Sent from my iPhone> On Feb 11, 2015, at 10:40 AM, "Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC]" wrote:> > Glen=C3=A2=82=AC=9Dlooks like you=C3=A2=82=AC=84=A2re making great progress on your Pietnepol biplane!> > Do you have a color scheme and engine picked out by chance yet?> > Mike C.> Ohio> > ky=C2=B7=C3=A8=C5=BE=C3=9B"=C3=8D=C3=AD=C5=93=C2=A2Z+=C3=93M4=C3=93G=C3=9Aq=C3=A7(=C2=BA=C2=B8=C5=BE=C2=AEw=C2=B0r=B9=C2=AB=B0=C3=C3=93=C3=A3=C3=A2z=C3=97=C2=A7=C2=B0K=C5-=C3=8BD=84=A2=C2=A8=C2=A5=16=C5-=C3=AE=84=A2K=1E=C2=B6=17=C5=92j=C3=9A=C3=A8=C5=BE',.+-=15=C3=C2=AD=C2=BA=C2=B7=C2=AC5=C2=AB=C3=A2=C2=81=C2=ABh=C2=AE=C3=9A=1B=C2=AE=C5=92,z=C3=98^=84=A2=C2=A9=C3=B2.+-=C2=BA=C3=98=C2=A5=C5-=C3=98=C5=BE=C2=B2=C3=8B=C5=93=C2=AB=0B=C5-=C3=8BT=C5=B8=C3=B4=C2=AEn=C3=87+=C5-=BAb=C2=A2p+r=18=C2=AFy'=C5=A1=C2=AD=C3=88C=C2=A3 =C3=A5=C2=A1=C2=A7{ =C2=AC=C2=81=C2=AE=C5=92,x(Z=C2=B4P=10>=1A-=C2=A2=C3=88Z=C2=AD=C3=C2=A7vk=C5=93-k=C5=93-j+y=C2=A8ky=C3=B8m=C2=B6=C5=B8=C3=C3=83=0C&j=C3=9A=C3=A8=C5=BE',r=B0=C25=C2=AB=C3=A2=C2=81=C2=ABh=C2=AC=C3=B8=C5=BE=C2=B5=C3=A9=C3=A9=C2=A2R=C3=A2=C2=B2=C3=98m=C2=B6=C5=B8=C3=C3=83=0C&j=C3=9A=C3=A8=C5=BE',r=B0=C25=C2=AB=C3=A2=C2=81=C2=ABh=C2=AC=C3=B8=C5=BE=C2=B5=C3=A9=C3=A9=C2=A2R=C3=A2=C2=B2=C3=9F=C3=9A0=04=C3=918=C3=92=02Ia=01=14=C3=A4T1$=C5=A1=84=A2=C3=A8+y=C2=AB=C2=A2{^=C5=BE=C3'=C2=A5=C2=B2-=C2=AFj)ZnW=C2=AF=B0=C2=ABayg=BA=16=C5-=C3=AE=C5=A1=C3=86=C2=A1=C2=AD=C3=A7=C3=A1=C2=B6=C3=9A=7F=C3=BD=C3=BA+=C2=BAk&j=C3=9A=C3=A8=C5=BE',r=B0=C2=A1=C2=B6=C3=9A=7F=C3=BD=C3=BA+=C2=BAk&j=C3=9A=C3=A8=C5=BE',r=B0=C2h=C2=B8=C2=AC=C2=B4*'=C2=B6=C2=B8=BA=C2=BA=C3=98=C2=A8=C2=9Dg=BAJ+^N=16=C2=A7=9C*.~=C5-=C3=B2=C2=A2=C3=C3-zw=C2=AB=C2=A2=C3=AB,=C2=BA=C5=A1h=C2=AE=C3=93=1A=C2=B6=C3=90=C3=ABjY^.+-=01=C3=99=C2=A2=C2=9D=C2=A8ky=C3=B8m=C2=B6=C5=B8=C3=C3=83=0C&j=C3=9A=C3=A8=C5=BE',r=B0=C2r=B0=C3=AD=C2=AE&=C3=AE=C2=B6*'-=C3=9Bi=C3=C3=BC0=C3=82f=C2=AD=C2=AE=B0=C3=A2r=C3=87(=BA=C3=B7(=C5=BE=C3=9A=C3=A2n=C3=ABb=C2=A2=7F=C3=9A=C3=BD=C2=C3=9F=C2=A2{=7F=C2=C2=B7=C2n=A1r=C3=BE=1Bf________________________________________________________________________________Subject: Pietenpol-List: Re: Piet on eBay
