Pietenpol-List: Balloon tires?
Pietenpol-List: Re: Balloon tires?
Original Posted By: "Pietflyer1977"
Hi Pieter's,It's been a while since I have posted anything on the list. My main computer crashed and it took ages to get it running again. I checked the email account and there were around 700 emails waiting...mostly junk. However, amongst them all, I a found a mail from Jim Markle that he sent in January of this year. I have just sent a mail back to him a day or two ago apologizing for taking so long to get back to him...a 6 1/2 month later response time is a bit too long I think!Anyway, things are quiet on the Pietenpol front over here in Japan land. Both my friends Piet and mine have been dormant for quite while. Things are crazy busy at the moment and have been that way for a fair while but, I still fly my little r/c Piet to keep my sanity. That little model is now almost 14 years old.....and still going strong! Long live the Piet!Presently I am trying to learn gas welding in the hopes of being able to make up the metal fittings etc for my project.......I am a slow learner so even that may take a while!Well, just wanted to say g'day to everyone on the list and hopefully I can get on with the project sooner rather than later!Cheers to everybody!Mark StanleyJapanRibs done, fin/rudder done + a pile of sticks________________________________________________________________________________Subject: Pietenpol-List: Re: Balloon tires?
Hi Patricia, Great looking airplane. Rib spacing is just right. I just lovethose little (lights are not twinkling comments don't you.)Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Balloon tires?
Hello Good Pietenpeople!I an considering replacing the mid-70s skinny motorcycle tires in my Piet Air Camperwith the big balloon tires that Bernard had on a couple of his, like the1931 Air Camper 12236 with the 65hp Velie engine that can be seen here:http://www.pietenpolaircraftcompany.com ... o-galleryI think they are also on the Allen Rudolf Air Camper.They look to be maybe 16 to 18 in diameter. Does anyone know anything about thesewheels/tires? Thanks,JeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Steve;I have had both a taper shaft hub (A65) and a flanged hub (A75) on NX41CC and havehad props for both. On the taper shaft hub, there is a shaft that comes forwardthrough the prop and that shaft secures to the prop by a flange that isbolted to the face of the prop. On the flanged shaft, the flange on the noseof the crank does not have an extension through the nose of the prop. It hasdrive lugs that engage counterbored holes in the aft face of the prop and theprop bolts pass through the crush plate and prop into the threaded drive lugs.I don't know what your buddy is concerned about, because people who have orwant older airplanes with these engines are very aware of the differences betweenthe hubs and how to fit props to them. I have never heard anyone mentionanything like, "that's a taper shaft hub, I'm going to pass on it because I can'tfind a prop to fit it". The prop makers will bore and counter-bore yourprop as needed to fit either one.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Balloon tires?
Jeff; you might investigate the 'Dico' tires that a lot of the light planes like the AirBike have used and are using. I don't know who currently owns the design and markets them (maybe Titan), but they are balloonish tires with a 4 ply rating, a load range suitable to ours, and an "S-turn" tread pattern on them. Although they are not as tall as 16" or 18", they are sort of chubby and the price is quite reasonable. You can see them on my M-19 "Flying Squirrel", which is the airplane on the right, here: http://www.flysquirrel.net/hangar.jpg . The tires on my Air Camper (on the left in the picture) are 6.00x6 "Aero Trainer" tires, very good and very available at about $75 for just the tire, and you can see that the Dico turf tires are just a bit fatter and taller. For another possibility, you might look at the "Aero Classic" tires, which are meant to mimic the Stearman tire. Aircraft Spruce has the Aero Classic All-Weather and the Diamond tread, not cheap, although I think you are looking for the tires with just a straight groove tread. Nowadays the best cross-reference is going to be a turf tire like the golf carts use, or an all-purpose ATV tire.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Re: Balloon tires?
Original Posted By: "M W Stanley"
Hi Oscar,Thanks for the tip - this appears to be the Aero Classic solution:http://www.aircraftspruce.com/catalog/l ... effJeffrey H. Boatright, PhD, FARVOProfessor of OphthalmologyEmory University School of MedicineSent from an iPad with a spelling problem> On Aug 24, 2015, at 1:00 AM, "taildrags" wrote:>>> Jeff; you might investigate the 'Dico' tires that a lot of the light planes like the AirBike have used and are using. I don't know who currently owns the design and markets them (maybe Titan), but they are balloonish tires with a 4 ply rating, a load range suitable to ours, and an "S-turn" tread pattern on them. Although they are not as tall as 16" or 18", they are sort of chubby and the price is quite reasonable. You can see them on my M-19 "Flying Squirrel", which is the airplane on the right, here: http://www.flysquirrel.net/hangar.jpg . The tires on my Air Camper (on the left in the picture) are 6.00x6 "Aero Trainer" tires, very good and very available at about $75 for just the tire, and you can see that the Dico turf tires are just a bit fatter and taller. For another possibility, you might look at the "Aero Classic" tires, which are meant to mimic the Stearman tire. Aircraft Spruce has the Aero Classic All-Weather and the Diamond tread, not cheap, although I thin!> k you are looking for the tires with just a straight groove tread. Nowadaysthe best cross-reference is going to be a turf tire like the golf carts use, oran all-purpose ATV tire.>> --------> Oscar Zuniga> Medford, OR> Air Camper NX41CC "Scout"> A75 power>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ______This e-mail message (including any attachments) is for the sole use ofthe intended recipient(s) and may contain confidential and privilegedinformation. If the reader of this message is not the intendedrecipient, you are hereby notified that any dissemination, distributionor copying of this message (including any attachments) is strictlyprohibited.If you have received this message in error, please contactthe sender by reply e-mail message and destroy all copies of theoriginal message (including attachments).________________________________________________________________________________
Those are the ones I am using. Almost the exact dimentions as on the plans andI like them because they are smooth. I think they will give it the right look.RobRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/imag ... __________
Original Posted By: "Jack Philips"
Hi Rob,Neat! That looks just right. What wheels and brakes are you using and did you purchaseall if it from Spruce?Thanks,JeffJeffrey H. Boatright, PhD, FARVOProfessor of OphthalmologyEmory University School of MedicineSent from an iPad with a spelling problem> On Aug 24, 2015, at 6:43 AM, "Pietflyer1977" wrote:>>> Those are the ones I am using. Almost the exact dimentions as on the plans andI like them because they are smooth. I think they will give it the right look.>> Rob>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... 328#446328>>> Attachments:>> http://forums.matronics.com//files/imag ... ______This e-mail message (including any attachments) is for the sole use ofthe intended recipient(s) and may contain confidential and privilegedinformation. If the reader of this message is not the intendedrecipient, you are hereby notified that any dissemination, distributionor copying of this message (including any attachments) is strictlyprohibited.If you have received this message in error, please contactthe sender by reply e-mail message and destroy all copies of theoriginal message (including attachments).________________________________________________________________________________
RE: Pietenpol-List: Re: A65 taper shaft
The only problem with the tapered shaft hub (and I've owned 3 of them) isthat the hub is a separate part to be purchased. If you can find a NOS(New, old stock) hub they go for somewhere around $600. The hubs are proneto cracking and if you find an old one to buy, you should have itmagnafluxed to ensure that it is not cracked.The nice thing about the tapered shaft is that the propeller can be removedvery easily and quickly from the engine. The hub is simply unscrewed fromthe shaft and prop and hub are removed as an assembly from the engine.Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Subject: Re: Pietenpol-List: Re: Patricia's PietenpolPatricia, Just for reference. Some Bonanza Pilots carry empty plastic milkjugs. With two pilots in the front seats, None in the back and nothing inthe baggage compartment, we are forward of the CG limits. One or two milkjugs filled with water in the Baggage compartment brings us into CG.Note. Forward of CG and the plane gets so sluggish you may not be able toflare for landing. Aft of CG and the plane gets so twitchy that you mayover control and stall the plane. A lot of pilots get it backwards thinkingit involves the main wing. It has to do with how close the Center of weightis to the elevators. (You did not ask, nor do I think you don't know this,but it is a favorite subject of mine.)Blue Skies,Steve DOn Mon, Aug 24, 2015 at 9:47 AM, pjb wrote:>> Yes, that's true but make sure that it doesn't end up being nose heavy> instead...or nose heavv or tail heavy under some loading conditions.> For example, my piet CG is 18.4" aft of datum [LE] when loaded to the max> with 220 LB pilot,> 150 LB passenger, full fuel in nose tank 12gal, 10 LB baggage> ...this is excellent and well within allowable range.> However, when loaded with just me, 110 LB, no passenger and full fuel in> nose tank,> the CG is 13.9" aft of datum which is well forward of the most forward,> allowable CG of 15"> So, something will have to be done to rectify this - since I will mostly> be flying solo with no passenger !> According to the calculations, removing the nose tank and putting a tank> in the wing will bring the CG into allowable range. This is being done> right now !!> Anyone want to buy a Cub nose tank ?>> Cheers,> Patricia>> .....................>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... 446343>>-- Blue Skies,Steve D________________________________________________________________________________Subject: Pietenpol-List: Re: Balloon tires?
Douwe,Because you asked. ") This was written by my dad "Sparky Sparks" after we returnedhome from our 1996 adventure to Brodhead. Enjoy the story.See the attachment,Happy Landings all,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/an_a ... ___Subject: Pietenpol-List: Re: Balloon tires?
Original Posted By: "Andy Garrett"
$12,000US = $15,000 CDN!!!!! Sent from my iPhone> On Aug 28, 2015, at 12:43 PM, "Gary Boothe" wrote:> > > Round numbers - $12,000> > Sent from my iPhone> >> On Aug 28, 2015, at 9:23 AM, BritishJim wrote:>> >> >> How long is a piece of string....right?>> >> I'm in total state of indecision between building either a Piet, or Fisher'sR-80 Tiger Moth. >> >> Is there a rough...rough...rough...ballpark for the cost of building a Piet?I know that's going to open a can of worms due to all of the variables.>> >> I know it's going to be cheaper than the R-80, but I'm curious as to how much.I'd have to order all of my Piet materials from Aircraft Spruce, as I liveout in the boonies and don't really have any options for scrounging or visitinglocal suppliers.>> >> Let the debate begin. I figure it's less than divorce though, right? :p>> >> Jim.>> >> -------->> Your nose is high; you're in the sky. The other way around; you'll hit the ground....>> >> >> >> >> Read this topic online here:>> >> http://forums.matronics.com/viewtopic.p ... 471#446471>> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Balloon tires?
