Is this 1/8" ply required at hinges?
The plans show a 1/8" ply where the hinges go. That's with the hinges shown on the plans. Do I still need them with eye bolts using a large washer?
Re: Is this 1/8" ply required at hinges?
Post by Earl Brown »
John, that plywood gives the fasteners a stronger surface to tighten down on.
The spruce is too soft by itself.
donbrewer
Post by donbrewer »
YES ! You do need them, even using eyebolts and 970 washers. Don
Thank you Earl & Don!
John
