Gentlemen,The Piet with the LeBlonde radial was at Brodhead however it did not havethat engine on it any longer. It was in the back of a hanger with a Ford Aengine being installed on it. It is dark green with a red (?) stripe downthe sides.I have seen it flying in previous years. The LeBlonde sure made a neatlooking plane and flew well too. Several years ago they had some problemswith the engine (cracked crank). I asked around this year and got thestory: After more trouble with the engine they decided they needed a morereliable power plant. Jim >>>Steve, what radial are you considering for your project? I am not>>building yet but, I was thinking a small radial would be nice --haven't>>heard an "A" yet though.>>Well, even though I've heard from quite a few people that the HCI radial>(the one made from VW cylinders) is too light, I like the looks of it (who>am I to let a little thing like weight and balance to interfere with>coolness?
Pietenpol-List: Radials (Was: Brodhead 'n stuff)
>>I guess I'll take a closer look when they're further along with its>development. Maybe putting a little bit of electrical in would bring the>weight up. Maybe not.>>Then again, at Oshkosh they were showing a 3-cylinder radial from the>makers of the M14 Russian 9-cyl. That one might be a bit too heavy,>though. And Zoche is making a 4-cyl. 150HP radial that might be a bit much>power, but the weight might work. And I understand that there's a LeBlonde>(sp?) that some people have put on.>>As you can tell, I haven't gotten too far past the "Gee, a radial would be>cool!" phase...>>>Cheers,>> Steve Pugh> Senior Systems Engineer> Foundation Imaging>>________________________________________________________________________________
Pietenpol-List: Re: Radials (Was: Brodhead 'n stuff)
Original Posted By: jkahn(at)picasso.dehavilland.ca (John Kahn)
Yes, but my gosh, they had over 400 hours on the Leblond. In it's prime,it was considered a 500 hour engine. The crank broke over the Mississippi, and he (Davis), landed at Parariedu Chein.(or however!).I flew to Brodhead once to get Davis's Stinson, because the cam drivebroke atCresco, IA. It has spit pushrods out all over WI.JimV.________________________________________________________________________________
