Pietenpol-List: Vertical Systems
The address for Lars Nelson / Vertical SystemsVertical Systems34 Paradise RoadSanta Barbara, Ca. 93105e-mail: vertsys(at)west.net (this may not be working)Lars is active with this only if you prod him a bit. The Type II TransporterMountain / Alpine gear assembly that you need for this is pretty hard to findthese days.Cheers,Warren.________________________________________________________________________________
Pietenpol-List: Re: Vertical Systems
Original Posted By: "Conrad, Bart D"
Walt Evans,Lars Nelson's phone number is (805) 967-1415. Hope this helps.Mark BoyntonGilbert, Arizona> The address for Lars Nelson / Vertical Systems> > Vertical Systems> 34 Paradise Road> Santa Barbara, Ca. 93105> e-mail: vertsys(at)west.net (this may not be working)> > Lars is active with this only if you prod him a bit. The Type IITransporter> Mountain / Alpine gear assembly that you need for this is pretty hard tofind> these days.> Cheers,> Warren.> _______Get FREE voicemail, fax and email at http://voicemail.excite.comTalk online at http://voicechat.excite.com________________________________________________________________________________
