Pietenpol-List: New Builder Needs Special Plans
Hello,I am doing the research for a friend (who does not have a computer) that isbuilding a Piet. He has the Model A engine almost complete, and is ready tostart on the fuselage (and he is really anxious!).He needs the plans for the three piece wing and the full size template(plans?) for the wing rib. Is there a single place where these items can bepurchased without purchasing other plans?Also, he has been told to build the "longer" fuselage. His plans are for a163 inch fuselage. Should he build the "longer" fuselage, and if so, wherecan he get the plans for it?Thanks very much, Glenntrying to locate the full size template (plans?) for the wing rib. Also needthe three piece wing plan.________________________________________________________________________________
Pietenpol-List: Re: New Builder Needs Special Plans
Glenn Don Pietenpol has everything you need. Ted. T________________________________________________________________________________
