Pietenpol-List: Plans questions
Original Posted By: "Conrad, Bart D"
Sorry for replying to my own post but I forgot to put in a subject. I alsohad another question.On drawing #1 of the 1933 plans on the top down view I can tell what's goingon at the tail end. Are there 3 gussets across the back?One 7" A 6" space A 2" gusset A short spaceThen a 4" gussetIf so what is the 2" gusset for?Thanks Marc ----------------------------------------------------------------------------------------------------------I have some questions I hope you guy can shed some light on.Does anyone know of a direct drive Subaru EA81 Peat? What kind ofperformance?Over and above the 1933 plans what are the other Peat addendum available andwhat are the sources? I've head of the following:Builders ManualBuilding video1932 Flying and glider manualLong fuselage3 piece wingSteel fuselageCorvair engineEntry DoorHinged wing section for easy entryAny others you guy know about?Do you know sources for the above?Which of these have worked well or not so well?Thank you,Marc Davis________________________________________________________________________________
Pietenpol-List: RE: Plans questions
Original Posted By:> Davis, Marc[SMTP:marc.davis(at)intel.com]
That looks to be the mounting point for forward end of the vertical stab. Seedrawing # 2, middle and left hand top. That brings up a question for me. Shouldn'tthere be a cross brace under that gusset for the mounting bolt to attachto? The drawing doesn't show a brace there. Bart D ConradBoeing Field ServiceDC-9/MD-80/DC-10 & 737 Heavy MtcPhone: 713-640-5882/713-324-4192Fax: 713-640-5891Pager: 713-318-1625> ----------
> RE: Plans questions
Original Posted By:> > Davis, Marc[SMTP:marc.davis(at)intel.com]
the 2" gussett acts as a filer block and resting pad for the spar of thehorizontal surface. It is also through which the stab is bolted. Notnessasarily strutural to the fuse. The vertical stab is just screwed to thethe horizontal stab, not through bolted to the gusset (or fuse). But youcan put a crosspiece in if you don't mind about adding grams, ounces etc inthe tail of *your* plane..Just having fun,SteveeProvo UT>Steve EldredgeIT ServicesBrigham Young University> -----Original Message-----> Conrad, Bart D> Sent: Thursday, September 02, 1999 11:18 AM> To: Pietenpol Discussion> Subject: RE: Plans questions>>> That looks to be the mounting point for forward end of the> vertical stab. See drawing # 2, middle and left hand top.> That brings up a question for me. Shouldn't there be a cross> brace under that gusset for the mounting bolt to attach to?> The drawing doesn't show a brace there.> Bart D Conrad> Boeing Field Service> DC-9/MD-80/DC-10 & 737 Heavy Mtc> Phone: 713-640-5882/713-324-4192> Fax: 713-640-5891> Pager: 713-318-1625>> > ----------
> > RE: Plans questions
Original Posted By:> > > Davis, Marc[SMTP:marc.davis(at)intel.com]
Just as clarification... the bolt goes through the stab spar, the gussettand the top longeron on each side of the vertical stab.Hope this helps.Steve EldredgeIT ServicesBrigham Young University> -----Original Message-----> steve(at)byu.edu> Sent: Thursday, September 02, 1999 12:48 PM> To: Pietenpol Discussion> Subject: RE: Plans questions>>> the 2" gussett acts as a filer block and resting pad for the> spar of the> horizontal surface. It is also through which the stab is bolted. Not> nessasarily strutural to the fuse. The vertical stab is just> screwed to the> the horizontal stab, not through bolted to the gusset (or> fuse). But you> can put a crosspiece in if you don't mind about adding grams,> ounces etc in> the tail of *your* plane..>> Just having fun,>> Stevee> Provo UT>>> Steve Eldredge> IT Services> Brigham Young University>>> > -----Original Message-----> > Conrad, Bart D> > Sent: Thursday, September 02, 1999 11:18 AM> > To: Pietenpol Discussion> > Subject: RE: Plans questions> >> >> > That looks to be the mounting point for forward end of the> > vertical stab. See drawing # 2, middle and left hand top.> > That brings up a question for me. Shouldn't there be a cross> > brace under that gusset for the mounting bolt to attach to?> > The drawing doesn't show a brace there.> > Bart D Conrad> > Boeing Field Service> > DC-9/MD-80/DC-10 & 737 Heavy Mtc> > Phone: 713-640-5882/713-324-4192> > Fax: 713-640-5891> > Pager: 713-318-1625> >> > > ----------
Original Posted By:> steve(at)byu.edu[SMTP:steve(at)byu.edu]
I think I understand now. The vertical stabilizer gets screwed to the horizontalstabilizer and the horizontal stabilizer gets bolted to the upper longeron. Thanks!Bart D ConradBoeing Field ServiceDC-9/MD-80/DC-10 & 737 Heavy MtcPhone: 713-640-5882/713-324-4192Fax: 713-640-5891Pager: 713-318-1625> ----------
