Pietenpol-List: Douglas fir.
Re: Pietenpol-List: Douglas fir.
Yes I'm using douglas fir and the weight is not that great,to figure the difference you just figure total weight ofwood used probabaly not over 175 to 200 lbs now figurethe difference by calculating the cross products of a proportionsare always equal.spruce= 28lbs per sq.foot total weight of fuselage,tail,wing =200 lbsdouglas=33lbs per sq. foot total weight of fuselage,tail, wing=unkown33 X 200=6600 6600/28=235.7 you probably could cut down on dimension example=longerons from 1"x1" to 1"x7/8 and get the weight dwon to the same as spruce----- Original Message -----
Re: Pietenpol-List: Wood joysticks
Original Posted By:>> Rodger & Betty
Subject: Re: Pietenpol-List: Wood joysticks>>A lot of '20s biplanes had wooden sticks . . Wacos, Stearmans, etc. I'm>not sure they were "baseball bats" "axe handles" or anything else, but just>turned oak sticks. I had a friend get killed when the wooden stick broke>off in a Waco during aerobatics. That being aside, I would think twice>about a wooden stick in a Piet simply because the control cables attach to>the stick itself, above the hinge point. If you are going by the old>plans, both the elevator AND the ailerons attach up high. Purely from an>overly cautious standpoint, that does not sound like a good idea. In>addition, Waco/Stearman sticks are over 2" in diameter, a wooden stick as>small as a Piet wouldn't be all that strong.>>----------
I'm using a steel tube for my 'stick'. I plan on turning a wooden handlegrip out of cherry for the top two grips.Looks great and isn't all that hard to do. Lasts longer than the foam orplastic grips.I made one for my Kolb ultralight and it worked well.Greg YotzFit wings and control system. Looking at fabric.....-----Original Message-----
Original Posted By: "Greg Yotz"
Subject: Pietenpol-List: Douglas fir.Steve wrote:How many of yall are using Goug Fir in your construction. Are you makingany provisions for the weight differential? If so what are you doing. There really isnt that much wood used in the construction. I would say inall about 150lbs mebby. (Big guess)SteveSteve W GN-1 builder#6________________________________________________________________________________
>>>>>>> Ref. Wood joysticks>>>> I once saw a Stearman bipe with wood joysticks made from baseball bats>> which had been turned down on the big end to fit into a socket on the>> control system, looked great.>>>> Rodger>>>>________________________________________________________________________________
