Re: Pietenpol-List: Three piece wing fittings and header tank
Original Posted By: LaurenMWilliams(at)webtv.net (Lauren Williams)
Subject: Re: Pietenpol-List: Three piece wing fittings and header tank plumbingCrosby..can't help you re: the fuel cutoff but I did run across the problem you describe on the interference in mating the center section and wing fittings. I solved it by adding 1/16" ply plates under the c/s fittings. Now they fit nicely on either side of the wing fittings.Don Hicks ________________________________________________________________________________
