Re: Pietenpol-List: Three piece wing fittings and header tank
Posted: Mon Nov 08, 1999 1:49 pm
Subject: Re: Pietenpol-List: Three piece wing fittings and header tank plumbingCrosby..can't help you re: the fuel cutoff but I did run across the problem you describe on the interference in mating the center section and wing fittings. I solved it by adding 1/16" ply plates under the c/s fittings. Now they fit nicely on either side of the wing fittings.Don Hicks ________________________________________________________________________________
