Pietenpol-List: WIRE WHEELS
On the subject of wire wheels, does anyone know where 2/3 scale Jenny andNeuport builders get their wire wheels?________________________________________________________________________________Date: Mon, 31 Jan 2000 15:01:15 -0700 (MST)
Re: Pietenpol-List: Re: Grega Landing Gear Question.
Original Posted By: "Domenico Bellissimo"
Not sure how you ruined two legs. All I did was lock mine into the vise withsome support under the pipe an started to mill through. You should ensurethat it is in the middle of the pipe and continue milling through to theother side of the pipe on the same stroke. DO NOT do one side then theother or you will lose your alignment.And yes any machine shop can do this for you, but it gets expensive after awhile. It's best to do it yourself if you have access to a machine shop.Good Luck.Domenic________________________________________________________________________________
