Original Posted By: "Chris and Carrie Tracy"
I had a feeling that kitfox smooth tires were not a/c type. So went thru boxes until I found my old info packet on that plane.A close look at the picts showed that the tires are 4-wheeler atv type,with maybe the tread turned off smooth. And the wheel rims are 4 or 5 lug bolts like atv's have. Also a pict of the axle hub looks very much like what a guy would see on an atv in the cycle shop.20x7x8 tires are a standard item on 4 wheelers to.So it seems that the kitfox wheel tire set up could be pretty much a standard list of items. Available in most any bike /atv shop.Bob________________________________________________________________________________
