Pietenpol-List: Wood
Original Posted By: Airplaneman123(at)aol.com
Subject: Pietenpol-List: WoodI second Carl Loar's comments on wood from Western Aircraft. If you usesubstitute wood, you must still make sure it is aircraft grade. Thistakes education and time and wasted wood on your part. Or you can turnit over to a professional and use that time to learn welding, fabric, orother necessities of airplane building. Leon S.________________________________________________________________________________
RE: Pietenpol-List: Wood
Pietenpol-List: Re: Wood
Consider the covering for your fuse as "structural".If you live near the border, see if you can go across today and come backwith Canadian lumber without paying the new tariff. Bush declared anaverage 29% new tariff on Canadian softwood yesterday. I didn't see if thisis effective immediately. If not, I'd buy today and get it across theborder today, otherwise look at the Canadian dollar prices for lumber asmuch closer to US dollar prices.Mike________________________________________________________________________________
RE: Pietenpol-List: Re: Wood
I thought Bill Clinton signed a thing called NAFTA which stood for the NorthAmerican Free Trade Agreement. What does a tariff have to do with freetrade? Hello?There goes any chance of expensive Canadian Sitka Spruce for the spars. Nowit is extra expensive.Chris Bobka-----Original Message-----
Re: Pietenpol-List: Wood
Original Posted By: dave rowe
Original Posted By: Gnwac(at)cs.com
Dave,I used Yellow Cedar for the wing trailing edges of my Pietenpol becauseof its high resistance to rotting in the presence of moisture. Sinceairplanesin general spend a lot of time just sitting, and the wing trailing edge of ataildragger will be a low point for moisture collection, I figured YellowCedar would be a good choice after being told it was the wood of choicefor pilings immersed in water.After thirty-three years, those trailing edges are still good--althoughthereis a bit of waviness evident when looking down the T.E. At the time I builtmy Pietenpol, there was some concern about getting a good glue joint withY.C. Aerolite glue was used initially and when the wings were stripped forrecover in 1985, some joints had indeed failed. These were re-glued withepoxy and they still seem to be sound. I would suggest making some testjoints with T 88 if you use Y.C.Port Orford cedar was used for the wing spars of a batch of BellancaSkyrocket bushplanes, built around 1945-46 by Northwest Industries inEdmonton, Alberta. It was beautiful stuff and apparently was nice to workwith. If you can find some, it would be an excellent choice for Pietenpolconstruction.I used Douglas Fir and Western Hemlock for my laminated I-beam sparsand Yellow Cedar "swallow tail" fillers at fitting points where bolts passthrough the wood. If Port Orford Cedar had been available, I would haveprefered it instead of fir (or even spruce, which I couldn't find at thetime).Next Saturday (November 15) I hope to fly CF-AUN on the 33rd anniver-sary of its first flight.Cheers,Graham (Camrose, Alberta, Canada)________________________________________________________________________________
I just ordered my plans for my pietenpol. Who do most of you order your wood from?________________________________________________________________________________
I got most of mine from Wicks Aircraft Supply http://www.wicksaircraft.com/, and some from Aircraft Spruce and Specialtyhttp://www.aircraftspruce.com/Jack PhillipsNX899JPRaleigh, NC-----Original Message-----
Original Posted By: Dan Yocum
I got mine from Aircraft Spruce. Aside from one minor, and one not so minor problem,the material is great. For the record (for those that weren't readingthe mail a few months ago), Aircraft Spruce quickly took care of both issues.--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 06 Mar 2010 18:56:18 -0600
William,Those who have been on this list for a while know that I would be remiss ifI did not point out that you are not locked in to using A/C Spruce. I haveHemlock in my tail, and the rest is Poplar, including the ribs. All wasbought at a local hardwood supplier for under $300.Gary BootheCool, CAPietenpolWW Corvair ConversionTail done, Fuselage on gear18 ribs done-----Original Message-----
Original Posted By: Mike Townsley
If you down a ways on this page you will see a chartof wood strength and weight;http://clifdawson.ca/Tools_and_Tips.htmlMy plane is entirely Western Hemlock with Fir LandingGear and Cabanes. I have found 1" wide Fir planks for mySpars.ClifThe voyage of discovery is not in seeking new landscapes, but in having new eyes.-Marcel Proust -> William,you are not locked in to using A/C Spruce. I have> Hemlock in my tail, and the rest is Poplar, including the ribs. All was > bought at a local hardwood supplier for under $300.>> Gary Boothe________________________________________________________________________________Date: Sat, 06 Mar 2010 23:37:19 +0800
Original Posted By: Pastor Mike Townsley
Gardinier & Ben,I envy you guys - hope it continues to go well. Ben - $3 trim system? Cheapskates everywhere (i. e. ME) want to know! Details?Kip GardnerOn Mar 6, 2010, at 7:20 PM, Ben Charvet wrote:> >> I too am flying off my hours. Today was my first test of the $3 > elevator trim system I installed yesterday. Prior to this I was > holding a lot of back pressure for level flight. I also added 1/2 > inch of offset to the rudder. Now I can fly hands off for a few > seconds while fumbling around changing frequencies, etc. Today was > pancake EAA pancake breakfast day for my chapter. When it came > time to land the wind was blowing 8 kts right down the paved > runway. I basically flew it right down to the pavement at 65 mph > and about 1000 rpm. In spite of the large audience by carrying a > little power I was able to do a nice wheel landing that was heard > more than felt, pulled the throttle, pushed the stick forward, and > still only rolled out about 150 ft. My flight advisor suggested > wheel landings, and I think they are best done with a little power on.>> Only 19 hours to go!>> Ben Charvet> Mims Fl>> On 3/6/2010 7:04 PM, airlion wrote:>> --> Pietenpol-List message posted by: airlion>>>> I am flying my hours off and after 5 hours I am really impressed >> on how my ship handles. It really likes 85 mph at 2500rpm. and >> will easily go to 95 RPM at 2900 rpm. On final approach to >> landing I am trying to get used the sink rate for landing. I like >> to land power off like I was taught., but i FIND THAT IS NOT >> POSSIBLE. I have been reading about dimple tape as a somewhat >> solution. Have any of you experienced pietenpollers tried this and >> does it work? Thanks guys, Gardiner Mason>>>>>>>>>>>>>>>>>>________________________________________________________________________________Date: Sun, 7 Mar 2010 21:29:33 +0800Subject: Re: Pietenpol-List: Wood
I don't have many details really... I just followed the details in Bingelis' bookand adjusted for my spar spacing. The distance between spars is 27 3/4"... my spars are 3/4" thick... that tellsme that I needed to space the arms 28 1/2" apart. The main uprights are 2x4sand the arms are 1x4s (I think), but it really isn't that important, just as longas the material is sturdy enough to support the complete assembly. The armsextend ~5" outward (to support the full width of the spars) and they are supportedby a couple of diagonals, cheap 1/4" plywood gussets, Elmer's wood glueand a few small nails from the nail gun.I used a shim to level the pair and clamped them to my workbench. The rest canbe seen in my log book photos or Tony's book, "Kitplane Construction Techniques."--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wood
