Thought I'd pass on how I built my wing attachment fittings going to thecabane struts. Instead of the two overlapping U's (Where the upper U goesover the spar and the lower upside down U goes over the cabane strut) Ijust used a longer U with a piece of tubing welded in the bottom of the Uto put the wing bolts thru. The bottom of the U goes right into thesomewhat squared off upper end of the cabane struts. On the end of thelower bolts that go thru the rear spar I intend on putting the aileroncable pulleys. This puts the bottom of the pulley just about flush withthe bottom of the wing, which is a bit low but does not seem to interfere. Wayne Sippola, Winnipeg________________________________________________________________________________
