Original Posted By: "Domenico Bellissimo"
Subject: Pietenpol-List: elevator hingeshas anybody had a problem getting a nut on the last screw of the most outside elevator hinge, the one that is just under the diagonal brace? if so i would appreciate any suggestions on the best way to handle it. thanks, Robert Bush________________________________________________________________________________
Re: Pietenpol-List: Alum head vendor
Original Posted By: "Rodger & Betty Childs"
Actually the best color the block is Black. It is the color that helps todissipate heat the most. Any other color will insulate more than blackdepending on it's wavelength. Silver/Aluminum and white paint would be theworst. Just look at any anodized electronic heat sink, they are for the mostpart flat black, not shiny.Regards,Domenico Bellissimo________________________________________________________________________________
