Pietenpol-List: Cracked Spars
"Rodger & Betty Childs" Concerning the "cracked spars";The proper way to "patch" the spar is to cut off the 12-16" cracked end andcall this the inboard end of the spar and to cut off the other crackedend and splice in the required length using a 12-1 scarf with the proper plyplates on each side of the spar covering the splice.Rodger ChildsPiet in progress________________________________________________________________________________Date: Mon, 25 Sep 2000 17:44:26 -0700 (PDT)
Original Posted By: "Domenico Bellissimo"
"Rodger & Betty Childs" I never saw spar repair by filling the crack with glue called out as an acceptable fix in any FAA manual. I don't think Spartan or anyother A&P school calls out doing it that way either. I just have trouble with that way of repair.Try to get the spar blank replaced as not being what was wanted orordered, or use it in some other capacity.RodgerPiet in progress________________________________________________________________________________
Re: Pietenpol-List: Cracked Spars
Original Posted By: Michael List
