Pietenpol-List: flight intstuction in a homebuilt
Subject: Pietenpol-List: flight intstuction in a homebuilt
Re: Pietenpol-List: elevator horns
"Michael Brusilow" >>> Sorry guys, I don't agree. I makes more sense to have a direct pull onthe>> horn than an angular pull.>>>> Mike B Piet N687MB ( Mr Sam )>>But Mike, how did you make the bolt holes centered on the spar with thehorn angled?>Also, like I said earlier, the angled horn pulls the spar in a strange way(although I>admit the angled cable may do the same thing). What about twisting the topof the horn>to point at an angle? (I have flat plate elevator horns)I too have flat plate horns.The horn is notched to fit over the spar withbent out tabs on either side. Position the horn & drill the holes. There isof course an extension welded to the horn which is bolted to the elevatorbeam.( I hope I remember this right, its been over 14 years since I made theelevator. Although, I did check with Ed Snyder ).Mike B Piet N6987MB ( Mr Sam )________________________________________________________________________________
