Original Posted By: "Owen Davies"
Ben,The only thing about the plywood being "cabinet makers wood", is that youwould need to be sure it was made of exterior ply and not interior ply.Also, it may be that in "cabinet makers wood", the plywood may have knotsand voids in the inner plys while the surface plys are beautiful specimensof wood. This would make it weaker than aircraft grade plywood where theknots and voids are cut out and filled with solid wood inserts.Rodger ChildsPiet in progress________________________________________________________________________________
Pietenpol-List: Different Woods
Pietenpol-List: RE:
Believe it or not, but I just sunk a 3" wood screw through the wingtip intothe tip of the spar. Steve E.-----Original Message-----
Re: Pietenpol-List: RE:
Original Posted By: "Alan Maragret & Debbie James"
Subject: Re: Pietenpol-List: RE: Hey,These ailerons are more work and trouble and sensitive in alignment than anything I've encountered. I have little L clips holding the bows to the spars but it wouldn't work out so I'm going for corner blocks glued in for the bows on the ailerons. Hope it holds.Corky________________________________________________________________________________
