Pietenpol-List: Re: Propellers
Posted: Sun Apr 29, 2001 1:24 pm
Original Posted By: "Mike Bell"
Mark,I believe the important thing about the L/G attach fittings is that they end up mounted on the lower longeron centered at the same location as a verticalor diagonal upright, this is also important for the lift strut attach points. This is why J Grega had to put an extra bay in his fuselage sides when he wantedto use an actual Cub L/G that had a different center to center distance than aPiet L/G. You can always tell a GN1, or anybody who used a Cub L/G because therear lift strut and rear L/G do not hit the lower longeron at the same location.So assuming your fuselage sides are already built, the distance between the L/Gfittings is set.Hope this helps.Skip, still working on my shop so I can continue work on my L/G in Atlanta----- --- Cinda + Skip Gadd--- csfog(at)earthlink.net --- EarthLink: It's your Internet.________________________________________________________________________________Subject: Pietenpol-List: Re: Propellers
