04/30/2001 08:52:51 AMGo to the WEB site below for an old NACA report on propeller designfor small aircraft.Mikehttp://wais-gw.larc.nasa.gov:81/naca.larc.nasa.gov:210/naca/HTML/659/1=techreports.larc.nasa.gov%3A210;2=/usr/local/web/waissrc/naca;3=0%20659%20/usr/local/web/htdocs/naca/reports/1925/naca-tn-212/naca-tn-212.refer.html;4=techreports.larc.nasa.gov%3A210;5=/usr/local/web/waissrc/naca;6=0%20659%20/usr/local/web/htdocs/naca/reports/1925/naca-tn-212/naca-tn-212.refer.html;7%00;YES, the whole thing is the WEB address________________________________________________________________________________Subject: Pietenpol-List: Re: Sides & Gussets
04/30/2001 09:59:04 AMOne of the notes that I've seen repeated on this list is that leavingthe side sheets off of the fuse until you're done with most of theinnards makes it a lot easier to install the innards. I'm at thestage where I have the sides together on my work table. With theinner gussets installed, the rigidity is quite sufficient and it takeshandling and bending the tail together just fine. I did one sidefirst with the gussets and then the second without. I think that Ihad to redo one of the butt joints________________________________________________________________________________
