question... a quick answer is appreciated as I'm hoping to glue the fusegussets on the left side tonight.The GN-1 plans are not clear on a certain area. Do the plywood gussets onthe insides need to have a 1x1 notch in them to allow the crossmembers tocontct the longerons when I join the sides, OR can I leave the gussetswithout the notches and just butt the crossmembers to the gussets and thengusset them over??sheesh how many times can you use the word gusset in a sentence??THX!DJ VeghMesa, AZGN-1 Builderwww.raptoronline.comN74DV________________________________________________________________________________
Pietenpol-List: fuselage gussets
Re: Pietenpol-List: fuselage gussets
Original Posted By: DJ Vegh
----- Original Message -----
Original Posted By: "DJ Vegh"
DJ,I did the 1x1 notch, seemed the simplest thing to do.DickG.----- Original Message -----
no, don't notch them. The gusset on the bottom holds the cross member in.The gussets are all that connect the pieces for the whole aircraft.----- Original Message -----
Original Posted By: "aviken"
You never know. Saw this Sale of an A65 motor linked on another forum. Somebodymay want to call and check on it.http://detroit.craigslist.org/wyn/for/4 ... ----Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: fuselage gussets
Pietenpol-List: Re: fuselage gussets
Watch out for Dan...He's a four-blader Mary Bethdanhelsper(at)aol.com wrote:> John,> > Here is some visual motivation for you my good friend. Time to put-on the Carhartz,get back over to the hangar and fire-up the chainsaw. If you make a mistake,just make the same one on the opposite side.....no worries! Next thingyou know its gonna be spring and you can test her out!> > Dan Helsper> Puryear, TN> > > > > ----------Bob 'Early Builder' DewenterDayton OHRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: fuselage gussets
