Pietenpol-List: Finding the sweet spot
Is there any set way of finding the ideal position of the prop in relationto the compression stroke. For instance, withthe prop in the two oclock postion, where would the number one cylinder bein relation to the cycle? I've got the corvairstarted a couple of times but I feel I'm not getting the best prop pull onit. If there is a little trick or procedure that mightmake it go better, I would sure love to hear it.Carl________________________________________________________________________________
Re: Pietenpol-List: Finding the sweet spot
Original Posted By: The Huizenga's
Thanks Kirk, I'm sure there is a trick to it. The fine tuning is more nutsthanthe building.Carl----- Original Message -----
