Pietenpol-List: The second easiest rib question
Original Posted By: "DJ Vegh"
Subject: Pietenpol-List: The second easiest rib questionWould someone please confirm my counting? I count 30 total ribs needed for the 3 piece wing, including 6 end ribs with the extra braces.Thanks________________________________________________________________________________
Re: Pietenpol-List: The second easiest rib question
Original Posted By: At7000ft(at)aol.com
I made 30 ribs and ended up with one left over. It is now a conversation piecein my office.The only ribs with the extra bracing are the two outer tip ribs.Greg CardinalP.S. Walt Evans has nice pictures of his plane in the latest issue of "To Fly" ----- Original Message -----
I hope so, I just built 30 of them.Dick N. ----- Original Message -----
Original Posted By: "Cory Emberson"
Subject: Re: Pietenpol-List: The second easiest rib questionIn a message dated 3/13/2004 8:27:53 AM Central Standard Time, At7000ft(at)aol.com writes:> Would someone please confirm my counting? I count 30 total ribs needed for > the 3 piece wing, including 6 end ribs with the extra braces.> > Thanks> Hi:You need to make 31ribs for the three piece wing. The 31st one is for hanging on the wall in your den/office. It truly is a work of art, and makes agreat conversation piece.Max DavisArlington, TX.________________________________________________________________________________
Original Posted By: dave rowe
Subject: Re: Pietenpol-List: The second easiest rib questionSo you have 28 full ribs in your wing, that is the same number as the one piece wing. You have 2 full ribs in your center section, and 13 ribs in the leftand right wings correct?I've only got 28, but have two half-ribs, due to putting a tank in thecentre section, so 30 sounds right.________________________________________________________________________________
