Dear 'A' Ford Engine Gurus,On my ('31) Ford I am currently using a single magneto per The Plans.However, I would like to add a second ignition source (magneto or battery)and wire both systems to one set of plugs. I have the engine's (former)starter location taken up by an oil filter, so that type of conversion isout. I guess that I will be adding something in the original distributorhole or . . . . ? Ideas Please! I am looking for some sage advice aboutwhat would be some good equipment choices and maybe even sources for same.Are there any known problems with using two ignition systems with one set ofplugs?Thanks,Larry PrangeNX1929A________________________________________________________________________________
