Original Posted By: Jim Cooper
According to the System Three Literature the upper service limit of T-88 is160 degrees F. I would guess that the internal temperature of a darkcolored wing could exceed this especially when sitting still on the groundin the summer time. Has anyone experienced (or heard of ) the adhesivefailing due to heat?Just wondering,Bob Bailey - Missouri________________________________________________________________________________Date: Fri, 23 Apr 2004 21:16:35 -0500
Pietenpol-List: T-88 Temperature Limit
Re: Pietenpol-List: AN latches
I used Aircraft Spruce part numberTL800G LatchTL800-5 StrikeI can provide some detailed pics of the latches installed if you'd likeDJ VeghN74DVMesa, AZwww.imagedv.com/aircamper ----- Original Message -----
also... the actual name is DZUS latches... I have no idea why I called them ANlatches... They are not an AN part number. I need to make that change on mywebsite.DJ VeghN74DVMesa, AZwww.imagedv.com/aircamper ----- Original Message -----
Re: Pietenpol-List: T-88 Temperature Limit
Subject: Re: Pietenpol-List: T-88 Temperature LimitIn a message dated 4/23/04 8:23:47 PM Central Daylight Time, baileys(at)ktis.net writes:>Good question. I have never heard of any failures, but always wondered about that, myself.Chuck G.________________________________________________________________________________
Re: Pietenpol-List: Horizontal stab question
Subject: Re: Pietenpol-List: Horizontal stab questionIn a message dated 4/23/04 8:53:17 AM Central Daylight Time, At7000ft(at)aol.com writes:>That is correct.Chuck G.________________________________________________________________________________Date: Fri, 23 Apr 2004 23:34:17 -0700
RE: Pietenpol-List: T-88 Temperature Limit
That's one reason I used resorcinolJack Phillips, Raleigh, NCStill spraying silver - getting close to putting color coats on -----Original Message-----
Thanks Cliff and Chuck,I guess my next question would be; does the strength return after it coolsdown or does it progressively get worse? In other words is the weakingprocess cumulative? It will be interesting to see the response from SystemThree on this.Bob B.----- Original Message -----
That is why I use Aerolite.Chris Bobka----- Original Message -----
