Pietenpol-List: T-88 Temperature Limit
Posted: Fri Apr 23, 2004 8:22 pm
Original Posted By: Jim Cooper
According to the System Three Literature the upper service limit of T-88 is160 degrees F. I would guess that the internal temperature of a darkcolored wing could exceed this especially when sitting still on the groundin the summer time. Has anyone experienced (or heard of ) the adhesivefailing due to heat?Just wondering,Bob Bailey - Missouri________________________________________________________________________________Date: Fri, 23 Apr 2004 21:16:35 -0500
Re: Pietenpol-List: AN latches
Posted: Fri Apr 23, 2004 9:45 pm
I used Aircraft Spruce part numberTL800G LatchTL800-5 StrikeI can provide some detailed pics of the latches installed if you'd likeDJ VeghN74DVMesa, AZwww.imagedv.com/aircamper ----- Original Message -----
Posted: Fri Apr 23, 2004 9:47 pm
also... the actual name is DZUS latches... I have no idea why I called them ANlatches... They are not an AN part number. I need to make that change on mywebsite.DJ VeghN74DVMesa, AZwww.imagedv.com/aircamper ----- Original Message -----
Re: Pietenpol-List: T-88 Temperature Limit
Posted: Fri Apr 23, 2004 11:04 pm
Subject: Re: Pietenpol-List: T-88 Temperature LimitIn a message dated 4/23/04 8:23:47 PM Central Daylight Time, baileys(at)ktis.net writes:>Good question. I have never heard of any failures, but always wondered about that, myself.Chuck G.________________________________________________________________________________
Re: Pietenpol-List: Horizontal stab question
Posted: Fri Apr 23, 2004 11:09 pm
Subject: Re: Pietenpol-List: Horizontal stab questionIn a message dated 4/23/04 8:53:17 AM Central Daylight Time, At7000ft(at)aol.com writes:>That is correct.Chuck G.________________________________________________________________________________Date: Fri, 23 Apr 2004 23:34:17 -0700
RE: Pietenpol-List: T-88 Temperature Limit
Posted: Sat Apr 24, 2004 7:59 am
That's one reason I used resorcinolJack Phillips, Raleigh, NCStill spraying silver - getting close to putting color coats on -----Original Message-----
Posted: Sat Apr 24, 2004 8:04 am
Thanks Cliff and Chuck,I guess my next question would be; does the strength return after it coolsdown or does it progressively get worse? In other words is the weakingprocess cumulative? It will be interesting to see the response from SystemThree on this.Bob B.----- Original Message -----
Posted: Sat Apr 24, 2004 4:58 pm
That is why I use Aerolite.Chris Bobka----- Original Message -----
