Pietenpol-List: Model "A" Cam Shaft
Original Posted By: "Larry Ragan"
I'm working on the engine for my Pietenpol and have 2 cam shafts with different dimensions on the llobes. Can someone direct to where I can get specs on Model A cam shafts so I can determine if I have an "A", "B", or modified cam shaft. Thanks Ron KaserNew to this list from Kellogg MNDiscover the best of the best at MSN Luxury Living. http://lexus.msn.com/__________________ ... __________
Original Posted By: KTS5TA6(at)wmconnect.com
Hi Ron I have an old Mac's ford Model A cataloge with specs in the back. It says the A cam is1 9/16" diameter on the bearings with a .302 lift....Hope that helps Ed>From: "Ron Kaser" >Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Pietenpol-List: Model "A" Cam Shaft>Date: Tue, 20 Jul 2004 10:08:09 -0500>>>I'm working on the engine for my Pietenpol and have 2 cam shafts with >different dimensions on the llobes. Can someone direct to where I can get >specs on Model A cam shafts so I can determine if I have an "A", "B", or >modified cam shaft.>> Thanks Ron Kaser>>New to this list from Kellogg MN>>_________________________________________________________________>Discover the best of the best at MSN Luxury Living. http://lexus.msn.com/>>http://search.ms ... __________
