Original Posted By: "DJ Vegh"
Subject: Pietenpol-List: Re: Pietenpol-List Digest: 19 Msgs - 09/06/04For "Leon Stefan"lsutks(at)webtv.netRe: Root rib covering.You don't have to stitch the root rib as the 2" cap strip is wide enough to make a good fabic bond with the covering glue (Poly Tac, Super Seam, etc.). Besure that the diagonal braces that keeps the fabric from pulling the rib and cap strip towards the tip are in place; the 2" cap strip & root rib will bucklewhen you shrink the fabric if they are not braced.Rogers Theetgecapnavid(at)AOL.com________________________________________________________________________________
