Pietenpol-List: prop - ground clearance
I have been told in the past the basic rule for prop ground clearance is 9 in.Is this correct? Is that figure with tail up in parellel to ground? With mynew radial engine Piet, I may have to re-make the gear legs to get it that high.Dick N.________________________________________________________________________________
Re: Pietenpol-List: prop - ground clearance
Original Posted By: Andimaxd(at)aol.com
Subject: Re: Pietenpol-List: prop - ground clearanceHi DickJust measured mine yesterday (for the umpteenth time). Exactly 9 inches with the tail up.Don Hicks________________________________________________________________________________
Subject: Re: Pietenpol-List: prop - ground clearanceI was told it was nine inches with one flat tire and the tail up.Max________________________________________________________________________________Date: Wed, 10 Nov 2004 10:34:48 -0800 (PST)
