Subject: Pietenpol-List: to add lightness, don't add things you don't needSteve--- You can build a good performing Air Camper and still have such things as brakes, tailwheel, tailwheel steeringa 17 gallon nose/firewall fuel tank, a roomy luggage compartment in the center section, and still come in (as mine did) around632 pounds empty weight w/ a 65 hp. Continental.Ways to avoid building a ground lover is to not add an electrical system of any kind (unless you absolutely have to for your airspacerequirements) don't put in front instruments, don't use carpet or upholstery, don't worry about the basic parts---build them just like theplans call for, use 3/32" cables instead of 1/8" where it calls for even tho the 1/8" makes some people feel more secure, avoid the autoengines unless you like the Corvair which has a good power-to-weight ratio, don't add a ventui or vacuum system or gauges that youshouldn't ever even need in a plane like a Pietenpol. If you need to use a radio and gps, use the hand-held versions---they work great.If you want more lift, add some length to the wings. Bill Rewey and others have made the center section wider to give a longer wingspan and with 65 hp Bill Rewey can haul some big passengers because of that added wing area. (plus his is a basic Piet--no frills.I'm sure others have some good suggestions that I've not mentioned, but don't go splitting hairs like wasting time pulling out rib nails orstaples after the glue has dried unless you are totally bored.Lastly----do not quit or sell your project. If you don't have a burning desire to complete this plane and fly it, just enjoy it as an enthusiastfrom the enthusiast's perspective. This is a long-haul project that will tax your will, patience, and time like nothing else you've ever done.But.....if you stick it out to the end, there is no better feeling of satisfaction and accomplishment.Mike C.________________________________________________________________________________
Re: Pietenpol-List: to add lightness, don't add things you don't need
Subject: Re: Pietenpol-List: to add lightness, don't add things you don't needMike,You have a very great gift of encouragement. That last paragraph almost brought tears to my eyes!!Dan HelsperPoplar Grove, IL ________________________________________________________________________________
