Pietenpol-List: Tire Pressures
A question for those of you flying piets on 6.00-6 tires. What tire pressure doyou carry?Bob HumbertN491RHA question for those of you flying piets on 6.00-6 tires.  What tirepressure do you carry? Bob HumbertN491RH________________________________________________________________________________
Re: Pietenpol-List: Tire Pressures
Subject: Re: Pietenpol-List: Tire PressuresIn a message dated 8/15/2006 6:27:03 PM Central Standard Time, slowbilder(at)COMCAST.NET writes:A question for those of you flying piets on 6.00-6 tires. What tire pressure do you carry?Bob HumbertN491RHBob,I have 8.00 - 6 Turf Type Tires from Wicks. I run 15 lbs. in them.Chuck G.NX770CG________________________________________________________________________________Date: Tue, 15 Aug 2006 19:44:20 -0400
Subject: Re: Pietenpol-List: airplane coversIn a message dated 8/15/2006 6:37:53 PM Central Standard Time, Isablcorky(at)aol.com writes:Oscar,You are beginning to get so excited about flying your Piet and going places and showing it off that it will probably be accused of being owned either by Elvis or Liberace.Nathan MossYou crack me up !! :)________________________________________________________________________________Subject: Re: Pietenpol-List: Tire Pressures
Bob,6.00-6 Airtrac 4 ply tires with 25 - 30 PsiHans slowbilder@COMCAS T.NET Sent by: To owner-pietenpol-l Pietenpol-List(at)matronics.com (Piet ist-server@matron Group) ics.com cc Subject 08/15/2006 06:23 Pietenpol-List: Tire Pressures PM Please respond to pietenpol-list@ma tronics.com A question for those of you flying piets on 6.00-6 tires. What tirepressure do you carry?Bob HumbertN491RH________________________________________________________________________________
There was an interesting discussion about this, wherein the utterly scientific Mike Cuy (or somebudy) suggested you get down on your knees and look at the contact patch between the tire tread and the pavement to make sure you have just enough pressure in the tires so the entire tread engages the pavement. Me, I'm a numbers guy and want to read some digits on a scale.The 6.00x6's on 41CC are supposed to be at 28-30 psi and that's where I have them. PS to Corky: I added valve stem extensions from AutoZone to them and made some holes in the wheel covers to allow the extensions to be accessible without continually removing the wheel covers. Turned out pretty nice, if I may say so myself.Oscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________
Subject: Re: Pietenpol-List: Tire PressuresI approve. But what about that fuse cover?Nathan________________________________________________________________________________
