Pietenpol-List: Tai Wheel Fittings
For some reason I can't seem to post this question.I tried sending this last night and it didn't seem to go through. So Iremoved the attachment and see if it works this time, It didn't.Sorry if you get multiple post but I need an answer to this question.On the stock tail wheel fittings, the tab that projects below the fuselage,do they get a slight twist so the hinge bolts are perpendicular to the swingaxis? this would make the tab parallel to the long axis of the plane.Without twisting the tabs, the a arm does not swing freely and the tabs flexas it swings. The plans for the A-arm suggest his but there are no notes ontheplans indicating to twist the fitting.So do I put a twist in it? or is there something wrong with my setup.This is my last and final try, as I'm off to Lake Tahoe to hang out at the beach with the kidsChris TracySacramento, Ca________________________________________________________________________________
