Pietenpol-List: Sheet metal suggestions for fittings and
Original Posted By: Larry Rice
Original Posted By: shad bell
> Re: Pietenpol-List: Sheet metal suggestions for fittings and
Original Posted By:> walt evans
Some cars do now have a roll over valve to shut the gas off if the car flips. Also it is a USCG requirement that a check valve be installed at the tank on a gas engined boat. What is the drawback of a check valve on an aviation engine. I understand that it is one other piece in the fuel system that could cause a power loss but it would be a great safeguard in a crash. I suppose the tank would rupture if the crash was severe enough and a fuelcell could help that. I think I heard someone say planes are not built to crash. What do you guys think?>From: Gary Gower >Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Re: Pietenpol-List: Sheet metal suggestions for fittings and >firewall>Date: Tue, 5 Dec 2006 17:45:18 -0800 (PST)>>The idea of the firewall is to hold the direct fire from burning the wood >and/or going to the cabin, meantime the fire is out, given that the pilot >shuts the gas and the master switch off at the real beguining of fire >(first smell),>Advise: Ffirst shut off then investigate the probably cause.>The firewall probably will hold the engine compartment fire time enough for >the plane to land and the pilot RUN out of it... Or when is only a little >amount of gasoline, burns off, in case of a faulty hose or broken gas tube, >or broken carburator leveler (sp?) (best scenario)>>If the galvanized is burning fumes already... Real bad luck! The poor >pilot is already so burned that will not make it consious (or alive) to >the crash land zone, galvanized fumes or not.>>The pilot has to be alert to stop the fire in the beguining.... Is like >trying to put a house fire off with a hand stinguisher... The hand >stinguisher is to open the way out as fast as possible of the burning >buildimg. or to stop a little beguining fire.>>The cars get totaled when fire because two things: The gas tank is level >with the car and the gas keep driping out and making more fire, (No shut >off valve in cars) or the shorted electric cables keep burning until >the BIG batery in the car looses his charge (No Master Switch)...>>Hope I am right... Better: Hope no one of us be ever in this cruel >scenario!!!>God Bess Us.>>Saludos>Gary Gower.>>Dennis Engelkenjohn wrote: If, God forbid the >worst happens and there is a fire, won't the galvanizing burn off and make >a poisonous gas? I remember WW saying something about how bad the fumes >were from his teaching of welding days.> dennis Engelkenjohn> ----- Original Message -----
