By two pack I did not refer to two cans of the same product, but one canof the basic varnish & one can of hardener.As suspected if you use the Dacron Stitts process for covering & use thewrong varnish, the Polytac will react & may destroy the varnish.If this happens then the whole integrity of the covering may beaffected.Graham Hewitt________________________________________________________________________________Subject: Pietenpol-List: fl ying from Oshkosh to BrodheadDate: Fri, 8 Dec 2006 15:15:40 -0600
