Subject: Pietenpol-List: Engine selection questions > Merry Christmas All! > > I'm starting to look for a mid-time 0-200, or possibly C-85 or 90. > Should I be looking for the F (flanged hub) designation? Are there > other things I should be considering? > > Thanks, > > Jack > > www.textors.com > > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Wing Rib Lacing
Subject: Re: Pietenpol-List: Wing Rib Lacing> > Mike> > Stand the wing on its leading edge, about 2 feet up from the ground> > Make 12 needles, using welding rod (flat one end with hole, sharp the> other)> > And do all the ribs at the same time, saves time walking around > the wing> for every stich.> > Even faster get a stich buddy, saves the walking altogether> > Have a merry christmas> > Hans> > > > > > > ________________________________________________________________________________
Re: Pietenpol-List: Strut vibration
Subject: Re: Pietenpol-List: Strut vibrationIn a message dated 12/22/2006 9:28:31 AM Central Standard Time, at7000ft(at)gmail.com writes:ChuckArn't they just talking about securing the ends with castle nuts so they can move forward and backward rather than tighening them down with regular nuts? Idon't think they meant to have you enlarge the holes. Rick The only place castle nuts are required is where there is a movable joint. I can only be sure, in time, the holes will elongate if the bolts are loose enough to allow movement, unless there is alowance for routine lubircation. Iused locking nuts, and cinched them up with about 30 lbs of torque. The note in the plans has to do with 1020 steel, not 4130. Not sure if that makes a difference, but 4130 certainly has more tensile strength.Chuck G.NX770CG________________________________________________________________________________
Subject: Re: Pietenpol-List: Wing Rib LacingIn a message dated 12/22/2006 11:58:58 AM Central Standard Time, hans.vander.voort(at)alfalaval.com writes:MikeStand the wing on its leading edge, about 2 feet up from the groundMake 12 needles, using welding rod (flat one end with hole, sharp theother)And do all the ribs at the same time, saves time walking around the wingfor every stich.Even faster get a stich buddy, saves the walking altogetherHave a merry christmasHansThat's exactly how I did it, but I only had 5 needles.Chuck G.NX770CG________________________________________________________________________________
