Subject: Pietenpol-List: Tech Counselor Anyone have any clues of where I could find a Tech Counselor in South Central Pennsylvania. My local chapter of the EAA is more of a social organization.I think I am the only one building, so that does not appear to be a viable option.Anyone have any suggestions or contacts I can talk to? I would certainly appreciate a contact.Please adviseThanksJohn ________________________________________________________________________________
Re: Pietenpol-List: Tech Counselor
Yes, Gene Briener in/around Gettysburg. Contact me off list and I can give you his info. He is a DER and one of the most knowledgeable out there with antiques and homebuilts.Gene ----- Original Message -----
RE: Pietenpol-List: Tech Counselor
There is a list of TCs on the EAA web site. There is also a list of flightadvisors. Since I am a TC I should know where the list is, but I can't seemto be able to find it myself right now.Brian KrautEngineering Alternatives, Inc.www.engalt.com -----Original Message-----
Here is the list. You have to log in to the web site.http://members.eaa.org/home/lookup/Brian KrautEngineering Alternatives, Inc.www.engalt.com -----Original Message-----
Re: Pietenpol-List: A 65 exhaust
Steve, I just noticed a set of Aeronca system heat muffs on e-bay. Not sure if your interested or not. So far at $10. with no bidders. Will end today You indicated you had found a good looking heat muff for straight pipes. Do you have an address?ThanksGene ________________________________________________________________________________Date: Sun, 30 Sep 2007 11:14:34 -0400
Original Posted By: airlion(at)bellsouth.net
Thanks Steve,I'm going to contact them and get some idea of which one I should use. Talked to my A & P friend yesterday and he says that he may have an extra set of straight pipes. He's out of town for a few days but will look when he gets back. If not, I will have a set made up as soon as I can (in the next week or two).Thanks againGene ________________________________________________________________________________
