Pietenpol-List: Wing Drop
Hi Guys,I went for a fly today with one of my hangar mates watching. He commentedthat every time he has seen the Piet fly (not just today), the left handwing drops just on lift off. I obviously pick it up with aileron on climbout and have not been conscious of doing it. The Piet flies hands off incruise with just a little nose down movement. A small amount of backpressure cures that.Any ideas as to what the cause of the wing drop is?CheersPeterWonthaggi AustraliaHYPERLINK "http://www.cpc-world.com/"http://www.cpc-world.com8:02 AM4:54 PM________________________________________________________________________________
RE: Pietenpol-List: Wing Drop
Jack,Thanks for the reply.I have a Corvair on the front so the rotation from the cockpit is counterclockwise. That would make the P-Factor the opposite way from a Cont orsimilar.Before I rebuilt my engine the Piet would fly hands and feet off for a whilebut since I have reinstalled the engine it tends to turn right a little. Ineed to realign the engine on its mount again. (The Corvair has largermounting holes than the diameter of the mounting bolts!)When I next fly, I will see if the elevator makes any changes to the roll.Cheers, Ill keep you posted.PeterWonthaggi AustraliaHYPERLINK "http://www.cpc-world.com/"http://www.cpc-world.com _____
Walt,Thanks, I hope things are as simple as that. I=92ll take notice next flight.CheersPeter.Wonthaggi AustraliaHYPERLINK "http://www.cpc-world.com/"http://www.cpc-world.com _____
Re: Pietenpol-List: Wing Drop
Original Posted By: walt evans
Agree with Walt, first few times I flew a stick homebuilt airplane I had the ailerons so uneven due to the position of my paw, damn near flew off the runway as soon as the plane rotated. Thought I had the rigging wrong or something else was messed up with the tailfeathers, just bad positioning of my arm.gordon ----- Original Message -----
>>>>>>Just to clarify my post, spar varnish is available in spray cans at the >>>hardware store.>>>I was multi tasking on the computer last night, no, I didn't varnish it.>>>Dick N>>>> _________________________________________________________________>> Help yourself to FREE treats served up daily at the Messenger Caf. Stop >> by today! >> http://www.cafemessenger.com/info/info_ ... tHMtagline>>>>>>>>>>>>> -- > 269.14.4/1057 - Release Date: 10/8/2007 9:04 AM>> ________________________________________________________________________________Subject: RE: Pietenpol-List: Wing DropDate: Tue, 9 Oct 2007 07:44:53 -0400
8/10/2007 4:54 PM________________________________________________________________________________
