Pietenpol-List: Wing Rib "Low Spot"?
Original Posted By: "MF"
You Model A guys are probably very familiar with Snyder's but they have severalbooks too.http://www.snydersantiqueauto.com/books/ABooksThey are a couple miles up the road from me, if anybody wanted me to go and checksomething out for them I would...Don EmchNX899DERead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Wing Rib "Low Spot"?
Original Posted By: RAMPEYBOY(at)aol.com
Hi,I'm working on my wing rib jig and I'm plotting the dimensions per the Hoopmandrawing #5 dated 3/3/34. I've heard about the illusive low spot but not exactlysure I know where it is or what's the fix. Comparing the plan drawing to pg.16 of the 1932 Flying and Glider Manual I found where Mr. Pietenpol correcteda dimension by 1/8". (6" corrected to 6 1/8"). (Pg. 16, far right column, secondparagraph from the bottom). Is the fix to add 1/8" to the dimension inquestion or am I going down the wrong track?Thanks,MattRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Re: Model A engine
Subject: Re: Pietenpol-List: Wing Rib "Low Spot"?Matt, I'm just a lurker here, but I remember reading about this too, and if memory serves, I think all you have to do is plot the profile out and "connect the dots", and it will be clear enough for the naked eye to see. Hope this helps...Boyce(http://food.aol.com/top-rated-recipes?N ... 0000000004)________________________________________________________________________________Subject: Pietenpol-List: Re: Model A engine
Pietenpol-List: Re: Wing Rib "Low Spot"?
Thanks Don,I checked their web site out, lot's of good stuff.Have you (or anyone out there) heard of a shop in Indiana that did conversionson the Model A?MattRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wing Rib "Low Spot"?
Thanks Boyce,MattRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
