Subject: Pietenpol-List: Aileron hingeScott: My brother is a machinist and he laughed when I asked him todrill a tiny hole for the microscopic cotter key-not enough bi-focals inthe world to make him see what he is doing clearly. I asked for advisefrom the list on obtaining a longer (longer than the 6" hinge) hingewire so I can bend it to the shape shown on a Cessna hinge in the AS&Scatalog. The end is a loop that will be secured under a screw. I don'twant to shorten the hinge to reveal enough wire for what I want to do.Someone suggested piano wire. It comes in .090 d. which I believe iswhat the hinge wire is. My only worry is that since it more than likelycomes coiled up, it may be hard to push threw the hinge. I Goggled,"piano hinge" and found some manufacturers who my be able to supplystraight wires longer than the 6' (AS&S sells bare wires that are only6") hinge. I haven't called any of them yet. If you talk to them, let usknow what they have. Leon S.________________________________________________________________________________Date: Thu, 3 Jan 2008 08:09:51 -0700
RE: Pietenpol-List: Aileron hinge
I just use a 1/16" drill bit to drill the hinge and use safety wire. Youdon't need to drill through the hinge pin, just keep the pin a little short.That is a fairly common way of securing the pins.Brian KrautEngineering Alternatives, Inc.www.engalt.com-----Original Message-----
Re: Pietenpol-List: Aileron hinge
Hi Jack......I installed my hinges before cutting the aileron free from the wing. It worked out great, BUT, I used the modified strap hinges as per the plans. They will simply poke through a slot in the fabric when covered. I don't see how you would be able to fit up a piano hinge before cutting the aileron free.... Ed Grentzer>From: "Jack T. Textor" >Reply-To: pietenpol-list(at)matronics.com>To: >Subject: Pietenpol-List: Aileron hinge>Date: Thu, 14 Aug 2008 09:33:38 -0500>>Awhile back, on another subject, someone stated they installed their>aileron hinge before cutting the aileron free. I'm trying to figure out>how to do that. Was it a temporary attachment? Also, after temporarily>mounting the hinge, have people had problems with a fit after covering?>I'm planning on using a full length piano hinge. If it binds, I will>cut into sections after it is attached.>>Thanks,>>Jack>>www.textors.com>>________________________________________________________________________________Date: Thu, 14 Aug 2008 08:29:50 -0700 (PDT)
Re: Pietenpol-List: Route 3/4" spar?
Original Posted By: "David Jones"
Original Posted By: walt
I did the same thing. Works fine and flies to--Jim Lagowski ----- Original Message -----
